4ft County Line tiller question
   / 4ft County Line tiller question #1
NoCowboyhat
BX2680
I have a 4ft County Line tiller and cannot find this anywhere...
- Can I used my Kubota Heavy Duty grease grease for the fittings?
- What is the oil capacity in the top and side gearbox?
Google is silent on this. The manual mentions GL5-85W 140 oil but doesn't speak of the capacity.
UPDATE: further searching found 1.5 quarts in each. The manual says it is shipped with gearbox oil...should I assume it is full?
I appreciate any feedback.
   / 4ft County Line tiller question #2
I would not assume anything...
Since you have the manual, it should also tell you how to check/fill the gearbox. If not, just fill it to the sight plug. Your grease should be fine.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 John Deere Gator Utility Cart (A55973)
2011 John Deere...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
SCREENER (A58214)
SCREENER (A58214)
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
