4820 Power Steering chirping since new
   / 4820 Power Steering chirping since new #1
stoyan79
Kubota L3700SU, TYM 4820CH
Power steering is chirping like low on fluid, or pump about to go bad.
Not all the time, but few times every minute.
Otherwise, it works fine.
Dealer says its normal?
Tested new 4820, 5520, 494, 594 on lot and most are chirping too. Weird.
Replaced HST fluid @ 50hrs with Amsoil, did not change chirping.
100hrs now, no abuse, and very low use.
   / 4820 Power Steering chirping since new #2
Is the fan belt tight? I've never heard chirping from low fluid. Low fluid will typically cause a growling noise. I've heard lots of chirping from loose or bad belts. 🤷‍♂️
I will check on this. Thanks.
   / 4820 Power Steering chirping since new #4
Does the chirping happen even when sitting stationary and not turning the steering wheel?
Does it change when steering vs not?
Does frequency change with engine RPM?
I am 99% certain that model has a tandem gear pump with one section for steering and other for implements so possible there is something in steering unit causing a chirp but not sure what it would be.
   / 4820 Power Steering chirping since new #6
I agree with Tinhack that the belt is the best possibility. If it's loose enough to allow it to bounce it's possible that it's rubbing on something such as the mounting bracket. Good luck.....
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2017 DODGE RAM 3500 DUALLY (A58214)
2017 DODGE RAM...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
PALLET OF SQ TUBING (A52708)
PALLET OF SQ...
2025 Mini Excavator (A56857)
2025 Mini...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
