Snow 4410 and moving allot of snow
   / 4410 and moving allot of snow #1
kwahl
Bronze Member
Western NY
John Deere 4320
I have reached my wits end adn realize that I need to get serious about moving snow. I have a 1800' driveway in WNY and my fel and Dodge ram are having a heck of a time.
I would appreciate information on the puma 74, using a JD 59 blower or any other blower, front or rear mount.
My JD dealer wants $3700 for the 59 and $279 fo rear chains, he said front chains void the warranty?
thanks,
Keith
   / 4410 and moving allot of snow #2
Keith,
I have used a 59 snowblower on my JD 955 and it works great. Like any other snowblower, you have to be prepared to get some mist in the face and you will look like a snowman unless you have a cab of some sort. Most of us don't and just tough it out. The front mount has the advantage of allowing you to face straight ahead. It also mounts and dismounts in less than 5 minutes. Even if you feel the need to use your loader for some work it is no big deal to switch from one to the other.
My greatest concern with the blower is when operating close to buildings, other vehicles, or people since it does throw chunks of ice or frozen snow and gravel. You have to be alert on aiming the spout so as not to point it at something. Otherwise it is a great way to move a lot of snow.
The price you were quoted is less than list. I would use chains unless you have agricultural tires (R-1).
JackIL
   / 4410 and moving allot of snow #3
The tire chains may hit the front of the tractor so the manual says. I bet Deere does not want the chain to fly off and strike the steering cylinder or part of the engine.
   / 4410 and moving allot of snow #4
</font><font color="blue" class="small">( <font color="blue"> The tire chains may hit the front of the tractor so the manual says. I bet Deere does not want the chain to fly off and strike the steering cylinder or part of the engine. </font> )</font>
I know JD does not recomend running tire chains on the front(why I do not know),but I have been using them on my JD 4400 and they have helped me a lot this winter.
   / 4410 and moving allot of snow #5
What type of tire do you have now on your tractor?
   / 4410 and moving allot of snow #6
I have the R-1 ag tires.
Before next winter I am going to make a set of the skidder chains for the front,with the center ring cleats.
   / 4410 and moving allot of snow #7
I have a 790 and use a rear mount 60" Lucknow snow blower
on a similar long driveway. It does a nice job. I have also used a rear blade in the past. It is true that you get alot of snow on you w/ a blower, and they also pick up stones in the gravel areas. Generally I'm satisfied w/ it.
Thanks for all the responses. I have checked out a PUma 74 with hydraulic rotation and deflection and it is $2500, much less than the JD 59 but I am still leaning towards the JD just because it would seem much more comfortable.
Any thoughts on where to get the front chains since JD does not recomened them? I have the R4 tires and I think they would benefit greatly from chains.
Thanks again, Keith
   / 4410 and moving allot of snow #10
I have the tirechains.com 2 link chains on the front of my JD 4200. They were under $75. and work well with the 4 link chains I have on the rear.
Bill
   / 4410 and moving allot of snow #11
hi, we have the jd 59 on our 4310 that we just got this year,it has been great.it will blow snow 30-50' depending on snow conditions and chute position.we also have the r-4 tires and have not had a problem yet using the 4x4 and ballast box on the back.front mount was the only way to go for us yes more money but no twisting around to use.being in ny we snowmobile so we had the heated shield outlet from our sleds put on the tractor so when its time to blow snow we suit up like going riding with helemt with heated shield and let the snow blow where it may no problems and stay warm and dry /forums/images/graemlins/grin.gif
   / 4410 and moving allot of snow #12
I've got the JD 59 front blower on my 4310 ehydro. I originally had the 59 on my 790. The 790 and 59 front blower were purchased in 1999. In april 2003, I traded the 790 for the 4310. I think the 59/790 combination did an excellent job
blowing snow. The 59/4310 combination is just a tad bit
underpowered. However, I have only used it one time this
season and that was to finally blow away all of the windrowed piles along the edge of the drive that had accumulated after a couple of weeks of using the 6 foot rear blade only for snow removal because I was too lazy to remove 430 FEL and put the 59 front blower on. So, I guess I was really giving the
59/4310 combo an unfair workout. I too have a 1200' driveway of white rock but I took the factory skids off the
59 and replaced them with home made sled runners. Here's a picture of the skids.
   / 4410 and moving allot of snow #13
here's a picture of the 4310/59 after nearly all of the snow
had melted off after using it. As you can see in the photo,
I have the turf tires and I have mfwd. I love my green.
   / 4410 and moving allot of snow #14
I want to make a suggestion, if not to late. In your photo the front guard for the FEL is still on the tractor. I found out if you rotate the defector ( Blower in raised position) it will hit the guard. I did not have any damage just a little missing yellow paint.
My 4300 has power to handle the 59" blower. I make sure to run in mid-range on the Hyd drive. In high it loses a lot, Low range is to slow.
DPR
   / 4410 and moving allot of snow #15
Tanuke01,
I already checked the clearance of front guard / discharge chute. It is close, but has enough clearance to miss.
It's about 1/8 inch. If I make sure the slack is
taken up and push the guard further back it clears about 1/4 inch. Of course, the tolerances on this kind of fit up are
not those of a fine swiss watch. It could be that the 4310 is
slightly different than the 4300. Who knows
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2018 Yamaha VX1050B-TA Waverunner Jet Ski (A59231)
2018 Yamaha...
CATERPILLAR 303.5E2CR EXCAVATOR (A60429)
CATERPILLAR...
45ft. T/A Flatbed Trailer (A59230)
45ft. T/A Flatbed...
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
