4320 Intake Air Heater Working?
/ 4320 Intake Air Heater Working? #1
sunnyside360
Veteran Member
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
It was -9 deg F here last night and +15 deg F around 11:00 AM today when I tried starting my 2010 JD 4320 tractor. Battery seemed to turn the engine over fast enough but just would not start. Tried pushing the key for 10 sec to activate the intake air heater and did not see any difference when trying to start. Then held key in for 30 sec with same results. I suspect the intake air heater may not be working. Does anyone know how to check the air heater? The dash indicator is illuminating when pushing the key.
/ 4320 Intake Air Heater Working? #2
If you raise the hood and preheat for 15 or 20 seconds. You should be able to touch the intake heater and feel temperature difference. If you can't tell, check it with a meter. You should get 12vdc when in preheat mode. Are you getting exhaust smoke? What color?
I just checked the tech manual on that machine. It shows glow plugs. Are you sure of your information?
Kevin, I don't have the 4320 shop manual. I posted based on info found in my owner's manual shown below and what was found here on tbn when searching on the topic.
9. For cold weather starting, use the intake air heater system. Activate the intake air heater system by pushing in the ignition key switch with the key, and holding it there for the required time:
10 - 15 seconds for temperatures as low as -18ーC (0ーF).
15 - 30 seconds for temperatures below -18ーC (0ーF).
/ 4320 Intake Air Heater Working? #4
Could be a serial number break. Look under the hood. The intake heater looks like a spacer with a wire on it.
/ 4320 Intake Air Heater Working? #5
not sure if it means that it is working, but when i push my key, i can hear the heater 'click'. don't know that i can get to mine to feel w/o removing the side panel...but i sure would like to find out! just don't feel like removing the loader to get the side panel off....of course, when it WON'T start one day, i won't be able to get the loader off to remove the side panel! anyone else not able to remove side panels w/ the loader on? i have a 4300.
i'm usually in a hurry when i need to use it for snow removal, but one of these days i need to actually get around to checking it.
/ 4320 Intake Air Heater Working? #7
I don't know what they cost, nor how hard they are to install, but you could invest in a engine heater and see if it starts as normal then. that would determine if it's a heating issue. Just a thought.
I also hear a loud click (relay) when depressing the key but don't know if the heater is actually working. I'll try holding my hand on the manifold after pushing on the key for 30 sec.
/ 4320 Intake Air Heater Working? #9
Are you plugging in the block heater? and it still wont start?
Almost sounds like fuel might be gelled up?
I'm assuming you got winter fuel?
Good question. I use Power Service additive (white bottle) year round. It's the same fuel (large storage tank) I use in two other diesel tractors both of which started right off with no difficulty yesterday.
Engine heater isn't a bad idea. However, I believe the tractor should have started if the air heater was working so would like to confirm it's operation. Tractor is under warranty but want to avoid trailering it a long distance to find nothing is wrong. I had a 2007 4320 and never had an issue with cold starting.
No block heater installed. I've used Power Service fuel additive for 30 years and never had an issue with gelling but I suppose there is always a first time. Think I'll check the voltage at the heater connection and if that is ok then check the resistance. Don't really know what the resistance should be but if it is infinite or very high resistance, I know the element is probably defective.
/ 4320 Intake Air Heater Working? #13
Resistance is 0.3 to 0.5 ohms. Attachment is from 4x10 tractor manual, but yours is the same. If it is working you should be able to feel heat on the heater case.
JD755, great info -- right on. Many thanks for posting info.
This photo does not look like my 4320 which has the JD Power Tech 4024T diesel engine. However, I'm quite certain the intake air heater is working. With a digital vom on the battery terminals and no load on the battery, the meter read 12.75 volts. With the key pushed in the relay slammed and the vom dropped to 11.8 volts. Tried this several times and the meter always dropped about 1 volt under load so I believe the heater is working, at least somewhat working.
Some suggested the possibility of fuel gelling so I doubled up on the Power Service additive and filled the tank with fuel. Temperature here this afternoon was 36 deg F so the tractor started fairly easy and I let it run for 10 minutes.
Hope all is well -- guess time will tell. Thanks to all for your help.
/ 4320 Intake Air Heater Working? #16
I just checked JD Parts and like kjung17 said it shows the 4320 does not have a preheater but instead has glow plugs. Probably why yours does not look like the picture. Are you familiar with glow plugs such that you know how to look for them? One or more of those may not be working.
Appears my 4320 Operator Manual does not match the tractor. Looking at 4320 documentation available, there are 4 different Operator Manuals depending on s/n range. So there may have been a change in glow plugs vs intake air heater but JD Parts should show the differences depending on s/n. I had a 2007 JD 4320 and I know there are differences.
Having had other older diesel tractors which had glow plugs, I do know what to look for. Guess I'm going to have to remove the FEL and have a closer look. :confused2:
/ 4320 Intake Air Heater Working? #18
There have been threads here for other JD models regarding the operator manual referring to glow plugs or air heater and not matching what the tractor has. Some of that has related to a s/n break between the two and the manual not being updated. In one case the manual was only partially updated, so it used both terms interchangeably. JD Parts shows three versions of your engine, but all three only show glow plugs. Curious to see what you find on yours.
/ 4320 Intake Air Heater Working? #19
Mine is a 2010 4320 and when I turn the key and push in, on the lower left lighted dash,
an orange "infinity-like" symbol lights (for the air warmer I assume), and an orange glow plug symbol lights on the the right side of the dash.
Steve
Steve
My dash panel operates the same as yours. I was concerned about whether the intake air heater (or glow plugs) were actually working. Having to plow a few inches of snow each day this past week here in the mountains of central PA, it only started hard that one day.
