4300 repeatedly breaks turnbuckle,
   / 4300 repeatedly breaks turnbuckle,
Re: Sorry Guys, no more Deere for me!!
Yes Rat, Actually Ive been a member for quite awhile, and it took awhile, but at some point, I remembered John from long ago. Really, I have been so busy trying to get our small business off the ground, and going back and forth with the dealer over this machine, I been neglecting my Computer, lol.
Plus at one time it crashed and it took me a while to find the site again.
As for the machine, I am a persistant person, Relentless, some might say. Its not even the money, but the principle of the matter. I definetely apreciate er'ones advise and I'll keep er'one updated as to what happens. Ed,,,,,,,,gott
   / 4300 repeatedly breaks turnbuckle, #52
I applaud your effort to establish a business. I also wish the best outcome from this dilema. The repeated breaks of the turnbuckle and finally the axle housing certainly don't appear from your description to be from neglect or abuse. Thats what makes it so puzzling. Your boxscraper, from your description, doesn't even seem all that heavy. My 72" weighs a little over 1000lbs. Rat...
WOW!! I dont belive mine wieghs that much. Its pretty heavy duty, but I can near pick up one end of it. Mine is 72" also, but not near that heavy. Rat, do you have a JD compact tractor? and if so, does the turnbuckle look the same as the one I posted on the web site? Or anyone else for that matter. Im wondering if my local dealer is using some cheap aftermarket turnbuckles?? Thanks, and I posted some pics of the axle housings and my tractor in pieces on the page "link above" thanks again,,,Ed,,,,,,,,,,gott broken tractor pics HERE!
   / 4300 repeatedly breaks turnbuckle, #54
I have a tiller I use in my poultry houses. The book says it weighs 740lbs. The tiller offsets to the right, so there's about twice as much weight on one side than the other. When I'm transporting and hitting bumps, you can probably multiply the weight on that one side by 3 or 4.
I just don't see the weight as being the factor in in your problem.
   / 4300 repeatedly breaks turnbuckle, #55
iamgott,
On the turnbuckle that failed, at the top of the assembly, is a ball and socket that slides onto the pin in the right side of the rockshaft. Does that ball and socket move freely?
It seems to me that if that joint isn't free to move, the normal side to side movement of an implement would try to bend the turnbuckle bolt and result in the failure of the bolt, in the same manner that a coat hanger will break if it is repeatedly bent in one spot.
The other thing that comes to mind is the possibility of installing the ball and socket the wrong way. I don't have the three point hitch on my 4300 right now to test my theory (using the backhoe today), but I suspect that if the ball and socket was installed backwards, it might bind on the rockshaft pin, causing the same end result that I would expect if the ball wasn't free to move in the socket.
Jim Fisher
Yes, I keep it lubricated and its installed correctly. I know, its befuddlin, The other side has never broke since I purchased the machine, only the right side breaks, still open for any suggestions. I really wonder if someone makes an aftermarket turnbuckle and thats what they use. Im gonna check with another dealer, or better yet, John Deere Themselves.
   / 4300 repeatedly breaks turnbuckle, #57
<font color="blue"> Yes, I keep it lubricated and its installed correctly. </font>
I wasn't thinking lubrication as much as a burr or a stray piece of weld spatter.
<font color="blue"> I really wonder if someone makes an aftermarket turnbuckle and thats what they use. </font>
I can't imagine the dealer buying an aftermarket part if Deere will supply an OEM part under warranty and pay them to install it.
That bolt must be at least 3/4" ... I use an MX5 mower on mine and have some pretty good hills on which I mow paths.
If the part is inherently weak, mine should have broken long ago.
Another thing that puzzles me is where it broke. I would expect the weakest spot to be where it is drilled for the roll pin. From the picture that you posted it looks like it broke right at the base of the threads.
Hope you figure it out.
broken turnbuckle
Yea Jim, It breaks on the bottom section, right at the end thread. Every single one breaks the same exact place. Keep thinkin, I really need to figure this out. and as for the one called Loner, That isn't called for, but oh well, some people just have to.
You know Jim?? I just thought of something, the links are at an angle, narrow at the top and spread out as they go down, I wonder if this would exert sideways stress? It still seems to be a straight pull but,,,,,,,,,,,,hmmmmn
   / 4300 repeatedly breaks turnbuckle, #59
Re: broken turnbuckle
<font color="blue"> I just thought of something, the links are at an angle, narrow at the top and spread out as they go down, I wonder if this would exert sideways stress? </font>
I don't think that it would. The ball and socket makes it act like a pendulum. The only way to get the side stress would be for the ball and socket to bind or exceed the range of the ball and socket.
Most all of the joints are ball and socket. Even where the sway arm attaches to the tractor, a ball and socket is used.
The only major joint that isn't a ball and socket is also the joint that is closest to the break. Even if the implement were offset to the point where it balanced on the right draft arm, the ball and socket at the rear of the draft arm would prevent it from twisting the draft arm and stressing the turnbuckle.
The only thing that I can see that would tend to twist the draft arm and stress the turnbuckle is the fact that the draft arm isn't perfectly straight. If that is the case, then I would expect to see a good bit of wear at the top of the draft arm on one side and at the bottom of the draft arm on the other side at the point where the bottom of the turnbuckle is pinned to the draft arm.
Ok, guess its back to square 1, hehe.
Maybe Im workin to fast, hittin bumps, jerkin it around to much, I dont know. I know a few months ago, I said I was gonna be real careful to see if I could keep from breakin it, and it still breaks, and always in the raised position. Not once has it broke while using it. Seems to me there should be a clue here. I know, a long time ago, I went to pull someone out of a hole. On the way back, I hit a chuckhole, a big one, and man did it bounce. I mean it made such a "KACHANG!!!" when I looked back I thought for sure it would have been broken, but it wasn't. But now, I can put on a new shackle, work the machine for 20-30 hrs, hit a small bump, and snap!! I guess, it really sounds like I'm doin something to cause fatigue and then when its had enough, it snaps?
I really just use the box to grade dirt, and I rarely grade or push backwards. I hardly ever use the brushhog, maybe twice a year, and its never broke with it on.
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
2022 FORD E350 BOX TRUCK (A57880)
2022 FORD E350 BOX...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
6' ROLLOVER BOX BLADE (A57192)
6' ROLLOVER BOX...
Doosan D355-5 Forklift (A55973)
Doosan D355-5...
