4300 Clutch Problem?
   / 4300 Clutch Problem? #11
The 3-pt cyl cover is under the seat, and operates what JD calls the "rockshaft". Normal
tractor companys call the whole system the "3-point hitch", or "3-point", or "3PH". The
cyl inside there lifts the two 3-pt arms.
Thank you, we found that "name" in the JD manual.
Looks like it's a good bit of work to get that cylinder/cover off. But since that would be on the way to splitting the tractor it won't all be lost.
Created = 1;
Domain = ".q13fox.com";
Expires = "2018-04-18 13:24:45 +0000";
Name = "_ga";
Path = "/";
Value = "GA1.2.1385226592.1460985679";
   / 4300 Clutch Problem? #13
You don't usually have to take the 3-pt cyl housing off if you are servicing the main clutch. I
admit that I am not familiar with the 4300 gear tractor clutch system. I have split other
gear tractors, however. Mostly Kubotas.
There are two places this one can be split, apparently. Dad was going to lift the 3 pt cyl cover to see inside where the range selector gears and forks are.
We learned a new clue last night. With the transmission in neutral, the rear axle cannot be rotated by hand in ANY range. But it will rotate when the selector is between a range.
Sent from my iPhone 2.0 using TractorByNet
White Metal Roof Panels (A55758)
White Metal Roof...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
23105 (A56859)
23105 (A56859)
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
