4115 Stalling
   / 4115 Stalling #11
After reading your last post, a safety switch comes to my mind also.
Especially when you said that when you put it in gear, is stalled again. Maybe check the neutral safety switch on the gearshift also.
   / 4115 Stalling
jd4115,
Dealer agrees it's probably the seat switch. I could not get it to fail today. I'm carrying a jumper wire for when, or if, it occurs again. If it does, I'll make sure it will start but cuts out as soon as I shift to gear, hopefully hold it on the slope with brake, bucket, and backhoe, jump the connections and see if it will go in gear without stalling. This is one of those intermittent problems that may take a while to be sure of the cause, and cure. If, and when, I'm sure what it is, I'll post the failure and correctiive action.
Thanks,
Tom
2016 DODGE RAM 3500 FLATBED (A58214)
2016 DODGE RAM...
Golf Cart (A55787)
Golf Cart (A55787)
2016 Sun Coastal 16' Cargo Trailer (A57148)
2016 Sun Coastal...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
DEL MORINO VICTOR FLAIL MULTCHING MOWER (A58216)
DEL MORINO VICTOR...
