Oil & Fuel $4000 Repl. Cost for JD Compact Tractor Fuel Pump??
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #21
Maybe one of those companies would be Bosch ?
A quick search for "diesel injector pump manufacturers" would probably confirm/deny what your friend told you.
I would think either Bosch or Roosamaster injector pumps for most Deeres'.
Steve
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #22
All Yanmar powered Deere compacts use Yanmars own pump. Yanmar builds the entire engine including the injection pump. I would say with less than 200hrs on the clock, that this paticular pump has had water, or some other type of contamination to cause the pump to fail.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #24
I just had the fuel pump, AM876266 replaced on my Model 790 JD, cost was $73.20 plus about $240 labor. Actually it was not the fuel pump that kept the tractor from starting as we discovered, it was a fuse.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #25
Didnt look it up, but $73.00 seems like that would be a Lift Pump, not the Injection Pump...if it is for the injection pump, A1!
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
Metal Peacock Lawn Art (A55853)
Metal Peacock Lawn...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55314)
2012 NEW HOLLAND...
Shell Antique Fuel Pump Art (A55853)
Shell Antique Fuel...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
