4 IN 1 FEL
   / 4 IN 1 FEL #11
Something else to consider..
A 4in1 is usually much heavier than a standard bucket so its important to have plenty of weight at the back so you don't lose too much rear wheel traction. You'll notice this most when you are using the 4in1 as a dozer. I have a backhoe on the back so my rear ballast is good. Without it I'd go nowhere. Then again, yours is a pretty good size tractor so you might not have too many worries about this.
   / 4 IN 1 FEL #12
Of course there is a better way. Get a set of forks that interchange with the bucket. Now you have a real lifting machine.
But lifting anything with a built-in hard point, will go better with chains.
Most forks also have a lifting eye or at least my Bradco Q/A ones due. So basically anything I can not get on the forks I can also lift with a chain Etc.
   / 4 IN 1 FEL
Somewhere i have seen a hook on a backplate which gets attached onto the front quick attack FEL arms ...but i cant seem to locate its name or who sells it...can anyone steer me in trying to find and have a look at it?
2013 CAT 312EL Excavator (A59213)
2013 CAT 312EL...
2110 (A58376)
2110 (A58376)
2 Disc Heavy Duty Bottom Plow (A57454)
2 Disc Heavy Duty...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2013 Vermeer SC1102 Towable Brush Chipper (A56857)
2013 Vermeer...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
