300 HR service mess - fluid spill!
   / 300 HR service mess - fluid spill! #1
lhfarm
Central Indiana
NH TC40DA
I'm just now doing the 300 hour service on my TC40DA, so you can tell I've not been able to use it much in the past 5 years. I read all the threads here, drove the 2 hours to the dealer (hour there and an hour back) purchased all the supplies and purchased a bunch of funnels.
It is a beautiful day here in central Indiana. 70 and sunny. I thought it would be a good day to be crawling under a tractor. So started the tractor to warm it and removed the wood splitter for easy access to the rear. Took 2 5 gallon pails and lined them with trash bags. Set one under each drain plug. I think the guy who did the 50 hour service has knuckles that drag the ground given the force needed to remove the plugs. Otherwise had little trouble getting the fluid to pour into the buckets.
That is when I made my error. That was going so well, I thought I'd work on the filters. While changing the front filter, I failed to notice that the back pail had gotten full every quickly and was starting to overflow. The damage was done by the time I got the plug in. It had slowed to a small trickle by then.
Not sure how much fluid went on the floor. I suspect not more than a quart or so, but enough that it took a roll of paper towels to get it up. I finished with the filters and put a little over 7 gal in. Started the tractor and drove it out of the barn. Checked at it was just at the top of the full mark on the dip stick.
So I have about an hour changing the fluid and going on 2 hours cleaning up the mess. That part of the barn floor hasn't been this clean since it was built. I haven't enjoyed the clean up and don't want to and won't repeat that mistake.
Did I make a mistake of draining both locations at the same time? Thinking about it, I assume the rear would be under the most pressure. In any case, I wanted to share my mistake, in hopes others won't have to do clean up work.
   / 300 HR service mess - fluid spill! #2
Don't feel bad...I can and do spill about 1 quart of used oil every time I change oil on my cars & trucks.
I think I am literally feeble / dumb / clumsy
And yes, I mean EVERY time...
Now I automatically place 4 of the oil soak up pads on the floor or ground first and then put the drain pan on top of them.
Maybe that is why when the wind blows and I am outside, I hear whistling coming from the down wind ear as the wind blows in one side and out the other ;)
   / 300 HR service mess - fluid spill! #3
I just changed all the fluids in my TC29 and managed to spill only a little. I think what saved me was the fact that I wasn't sure how much was going come out of each drain so I did one at a time and I used a drain pan like you would use for changing the oil in your car. As the drain pan got to be more than half full, I would put the plug back in and empty the pan into a 5 gal bucket. This process still made a mess, I don't think there is an easy way.
   / 300 HR service mess - fluid spill! #4
Rubbermaid or Newell?? makes shallow 10-12-15 size gallon pans that are perfect for changing oil. Fits perfectly under the tractor-at least my tc45a.
A friend got one from his work in the food industry and I used it and it works great.
It does take 2 people to drain the oil from the pan to 5 gallon buckets for recycling because it's akward with that much oil in it.
   / 300 HR service mess - fluid spill! #6
Got tired of cleaning up the garage floor after changing the oil on my 6.0 PSD Ford, so got one of those metal shallow, flat, drain pan thingies. Has a lip all the way around about 3/4" tall. Put my oil-catching pan on top of that, do my oil change, not a drop on the floor now. A quick wipe of the flat floor pan, and its ready for the next oil change.
Thanks for the ideas. I still have more fluid to change (front-end), so I'll be able to try some of the suggestions. I did get at least part of the floor scrubbed and swept a good part of the rest of the barn. :)
   / 300 HR service mess - fluid spill! #8
A barn doesn't have any character unless it's got stains everywhere! I have a full size hydraulic lift and a service station type oil drain receptacle that probably holds 10 gallons and I still manage to make a mess!
It seems like I always have some fecue grass on the floor around the lift from working on rotary cutters, finish mowers or my ZTR so i just sweep that stuff over to soak up any oil I spilled.
Fun doin' your own maintenance!!!!
Sam
   / 300 HR service mess - fluid spill! #9
Wow how did that happen
   / 300 HR service mess - fluid spill! #10
1. I save large pieces of cardboard. Easier to work on than a creeper, and you can pull everything out when you are done. Grampa passed that one on to me at the same time he told me you should have more oil in the bucket than on you. He was a heavy equipment mechanic. I believed him. Sometimes I still wear more than I should. Oh, when the cardboard is too oil soaked, throw it in the trash.
2. In addition to kitty litter, sawdust.
3. 5 gallon buckets are free from painters and 3~5 gallon buckets at your local bakery (including super markets). I have some that are only for oil changes. Don't need to clean them. And old GI type gas cans are perfect for oil return cans. Who cares if they have rust? And they are 5 gallons, which is all some places will take at once.
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
JOHN DEERE 250 SKID STEER (A51242)
JOHN DEERE 250...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
