3 pt lifters not going down.
   / 3 pt lifters not going down. #11
When you disconnected the backhoe, did you get the hydraulic connections on the tractor, back together the way they should be? Read the backhoe owners manual and it should show you how they should be when you remove the backhoe.
   / 3 pt lifters not going down. #12
If you did not do this DO NOT RUN YOUR TRACTOR until you do. With most backhoes, you risk grenadeing your hydraulic pump if you run with those hoses disconnected.
Aaron Z
thanks all. I put the 3pt on the actuator this morning and stood on the bars and it went down. Probably couldnt put enough weight on just the short actuator arms to get it to go down, seems to be working fine now.
   / 3 pt lifters not going down. #14
Galen,
If the BH is not connected to a remote, what are you describing?:confused2:
hugs, Brandi
   / 3 pt lifters not going down. #15
Galen,
hugs, Brandi
In theory you could run the BH off the powerbeyond port I think but it would be much less convenient at least for hooking up and disconnecting.
   / 3 pt lifters not going down. #16
Okay on the power beyond.:) But I thought that connection would just be a quick disconnect (QD), as in 1.:confused2:
Oh, I got it now..............one QD and two different lines to swap back in forth for two different uses.:thumbsup: Okay, I am awake now.;)
Had a hard time digesting it as I kept thinking about the QDs at the back of my tractor.:eek:
hugs, Brandi
   / 3 pt lifters not going down. #17
Powerbeyond ports are generally under the tractor so involve a bit more hassle than walking up to the rear remotes and connecting/disconnecting.
   / 3 pt lifters not going down. #18
Right, that is what I was thinking. But I was visualizing someone may have a QD there for a grapple, then change it for the BH, if they didn't have remotes back there. I always thought power beyond would be hard plumbed in before this thead started.
hugs, Brandi
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2005 International TranStar 8600 Hydro Vac Truck (A50860)
2005 International...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
