3 pt height
   / 3 pt height #1
joe swanson
Bronze Member
Adirondack Mts, Fulton County , NY
YM 336D
Can someone please tell me the height from the ground to the implement end of the lift arm for a cat 1 3 pt. mine seems awful high at 15 inches. Tough to connect to.
Joe
   / 3 pt height #2
Not sure of your question. If you are talking about the height with lift all the way down that is to high. You should have more than one set of holes in your side link where you can lower it. Yanmar Tractor Parts: Fixed side link
   / 3 pt height
Yes , I'm talking about the height with the lift all the way down. I know its to high that why I asked the question. What is the standard height. The lift arms are set in the lowest posssible hole. I can adjust the upper arm on the tractor as it is splined and looks to have been monkeyed with. But what is the standard height.
Joe
   / 3 pt height #4
There should be timing marks on the shaft, crank and lift arms.
   / 3 pt height #5
I don't know that there is a "standard" height. Depends on tire size, tractor size, and a few other variables.
A pic of what you have would be helpful, tractor, tires, etc..
   / 3 pt height #6
My Ym240 manual does not show the marks, just says they are there. I doubt anyone will be willing to unhook an implement to measure, so I suggest either dis/re-assemble according to the marks, or measure height of all of your implement pins and set arms so all will hook up.
   / 3 pt height #7
The 220 manual shows the marks right out on the end of splined shaft and on the outside of the lift arm. Should be easy to see per book picture. For what it's worth, on my 2002d with the pin in the middle hole on the side link, the lower lift arm is appx 10" off ground at center of pin hole.
   / 3 pt height #8
10 inches using the middle hole on the side link sounds about right for my YM240 too.
The YM186D with 16" rear tires is lower, maybe 4-5 inches from the ball to the ground, again with its side link set at the middle hole.
   / 3 pt height #9
someone mentioned tire size......I'm wondering if this tractor started out with smaller tires with the lift arms adjust to them and had larger tires installed somewhere down the line? causing the arms to be this high? just thinking out loud!.......................
some folks prefer turf over AG tires, and turf are usually shorter aren't they?
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
