3 point quick hitch on MF compact.
   / 3 point quick hitch on MF compact. #2
Hello Will,
I don't have one like that, but I do have a Pat's Easy Change. I like it so far. Just got it at Christmas so I haven't had it very long.
Hey Jerry,
Do you have a regular top bar, or a hydraulic cylinder?
Thanks,
   / 3 point quick hitch on MF compact. #4
I have a hydraulic cylinder from Surplus Center on right now. I need to get out and get some hoses for the new top link for Mark Carter.
Do you have pics of it Jerry??
   / 3 point quick hitch on MF compact. #6
I have the cheapo Harbor Freight version on my 1531. Works reasonably well. Since it locks the lift arms, you have to make sure all your implements have simliar spacing, but that's a one-time problem.
   / 3 point quick hitch on MF compact. #7
I bought a Woods version from a guy in town. He was selling it because the top hook was too big to fit his brush hog.
I will have to reweld my (custom made) receiver hitch to match the three-point setup I have for my backblade. Both the height of the top-link as well as the spacing of the lower mounts have to fit the quick-hitch.
The quick-hitch also has to come off for a post-hole digger, as these do not use a top link. If I hadn't gotten a good deal on this one, I would have gone with ones that mount on each of the lower arms, as they are more versatile.
JerryG said:
Hello Will,
After seeing Pat's Easy Change, I think that is the way I will go, with stabilizer bar.
Thanks.
   / 3 point quick hitch on MF compact. #9
Update on the one I just purchased used:
It won't fit my 6' back blade either. The top hook is too big to clear the pin and the structure of the back blade. So far 0 for 3 without modification of the implement.
   / 3 point quick hitch on MF compact. #10
I use a Pat's system. not a perfect solution but other than having someone else change implements for you, I don't think there is a perfect solution. I like the Pats system. You will need to go to a longer top link for most implements. Mine works well on my lifter(see pic) and on my woods RD7200 finish mower, box blade, bush hog, disk, and 2 bottom plow.
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2020 JOHN DEERE 35G EXCAVATOR (A51242)
2020 JOHN DEERE...
