3 Point Log Splitter : How to park for easy hookup?
   / 3 Point Log Splitter : How to park for easy hookup? #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have a log splitter and I need to rig-up some kind of stand for storing it. I tried using a few pallets so it was high enough to connect the lift arms, but it was too top heavy and rolled over on me. It is 350 lbs.
Before I attempt to put something stable together, I thought I'd tap into the users experience here. I have seen threads on Post Hole Digger storage, but not Log Splitters.
   / 3 Point Log Splitter : How to park for easy hookup? #3
I have a Speeco, and it has legs that it stands on, makes hookup easy.
   / 3 Point Log Splitter : How to park for easy hookup? #4
I just use spare jack stands from a garage sale.
   / 3 Point Log Splitter : How to park for easy hookup? #5
Mine is a little lighter but I think the same concept would work. I just slapped this together with scrap lumber and some cheap casters. If you are storing outside you might like real wheels on it.
   / 3 Point Log Splitter : How to park for easy hookup? #6
I bought mine with legs that bolt on to the 3PT hitch pins and a tripod with a pin on the front. Just two pieces of 2" u Channel with a foot.
I use this on the FEL for splitting as I use the BH for lifting and holding the log lengths.
   / 3 Point Log Splitter : How to park for easy hookup? #7
I store mine on a couple smooth rounds that have it about 8 inches off the floor. I have an inexpensive motorcycle jack I keep in the barn for moving implements around (it has steel wheels). On way or another I am able to use it on most of my lighter implements (chipper, splitter, snow blower, sander, tiller) that weigh less than say 600#. adjustable height and the coaster like wheels make hook up pretty simple. Also let's me tuck implements tightly out of the way in the corner of the barn for storage off season.
I think the bike jack was $100 at sears. Very useful, use it on ATVs, snow machines and of course, motorcycles, too!
   / 3 Point Log Splitter : How to park for easy hookup? #8
I have that same 2-way splitter and like it. Did you see they discontinued that one? On the replacement, they discontinued the bidirectional operation in favor of a vertical tilt. I just drop mine on a large round of firewood, sitting on end. It lives outside.
   / 3 Point Log Splitter : How to park for easy hookup? #9
Do you have enough remotes in order to operate the splitter and the back hoe at the same time?
   / 3 Point Log Splitter : How to park for easy hookup? #10
Achingback,
No, I simply unplug the BH connection and plug in the splitter - takes 2 minutes tops to swap. With the BH I will lift and cut 2-3 log lengths from the pile, which is 30-40 rounds then I disconnect the BH hoses and connect the splitter.
2-3 log lengths is about 1/3 to 1/2 cord depending on the size and this takes me about 2 hours or so - just about enough exercise in one day. Usually I have a cart or a pallet setup where I put the wood during splitting to minimize handling. Sometimes I just get lazy and make a pile..
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2008 Big Tex T/A Utility Trailer (A50860)
2008 Big Tex T/A...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
Adams Conveyor (A51039)
Adams Conveyor...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
