240 volt 200 amp disconnect switch question
   / 240 volt 200 amp disconnect switch question #61
in Texas, his feeders are probably only 18" down...at least they were when i worked in Lubbock Tx.
Yes, that would be NEC minimum, right? It would be a lot easier to make and pull a vault at that depth.
He wrote four feet, and I have no reason to doubt that. I think my well pump power line is below 24" here, but I haven't dug down to find it exactly. With all the burrowing animals around here (ground squirrels, coyotes, foxes, and badgers), if it were me, here, I would bury wire at least 48" or use conduit below 24" just to get it out of the way of the varmints. The badgers are amazing to watch and seem to disappear into our rock hard soil as if it is water. All of which reminds me that I need to go rototill some of the steeper slopes to spread some burrow mounds that are getting too tall to safely drive over. My limit is 30 degrees, and on a 20+degree slope, it doesn't take much of hump to make driving the tractor very uncomfortable.
All the best, Peter
   / 240 volt 200 amp disconnect switch question #62
The black circle is where my meter is. I have a 1,200 amp breaker box with six 200 amp breakers. I'm using three of them right now, including the one we're talking about.
What's a 1200 amp breaker box? Is that a 1200 amp service?
A property we looked at here in Oregon had an 800 amp service and a tiny 1 br modular home. I think they had plans to put in a large marijuana operation and decided to sell the property instead. The electrical service panel was huge!
Yes, I have a 1,200 amp service. When the power company was here to figure out what they needed to bring power into my land, they asked what I wanted. I replied that I wanted as much power as possible. He said they could do 1,200 amps for no additional charge. It seemed like a no brainer to me!!
   / 240 volt 200 amp disconnect switch question #64
Thats weird. Our coops here will install a 1200 if you asked…but your going to pay commercial rates every month. Everything above 400 amps gets hit with this. I guess texas really wants everything to go electric….this from a state built on gas.
   / 240 volt 200 amp disconnect switch question #66
I remember you had ideas about a RV park with lake and campsites… 1200 amp would give you that ability…
The Surgery wing has a single 1200 amp breaker ahead of the pad mounted transformer and I think it is 600 volts?
Giyi 59" Vibratory Roller (A57149)
Giyi 59" Vibratory...
Arctic Cat 650 w/Plow & Sprayer (A55272)
Arctic Cat 650...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
1775 (A58375)
1775 (A58375)
