2320 Drive Shaft U Joint blew up.
   / 2320 Drive Shaft U Joint blew up. #91
Eeek! (****, as I'm typing I'm realizing this thread is like...5 years old. But anyway...). Hope you figured everything out and were able to get the u-joint and everything fixed by the dealer without to much hassle. And for those of you stumbling across this thread like me - if you have to replace anything I reco ACV. Good stuff, decent prices, good support.
   / 2320 Drive Shaft U Joint blew up. #92
Stumbled across this thread myself. And may others I need to read.
My neighbors 2320, that's probably about 10 years old and 650 hrs, just blew the front joint apart. Won't get a chance to get it to my shop and tear into it til Monday maybe, but what little I see, it looks like the front yoke was toast.
I bout ***** when I saw the $700 pricetag of a whole shaft.
Given the age, it's unlikely dealer will do anything, even with their failure to mention it in the manual, or send the revision to her.
Guess I didn't realize this was a big issue til I started searching. Something like this, I would think, should have warranted a tsb or recall to correct damaged shafts, or to give a first round greasing for free or something to make owners aware?
   / 2320 Drive Shaft U Joint blew up. #93
Does this problem apply to a 2032R or is the 2320 a different design?
   / 2320 Drive Shaft U Joint blew up. #94
The 2320 is the same as the 2025r. I believe the 2720 and 2032 are different but I can not guarantee they don't have a similar issue.
   / 2320 Drive Shaft U Joint blew up. #95
Hopefully it didn't wreck anything on the trans/pump like this one did
http://www.tractorbynet.com/forums/...ating/199396-2320-hydro-drive-shaft-just.html
   / 2320 Drive Shaft U Joint blew up. #96
Didnt seem to. Just the driveshaft. Screwed up the yokes pretty good too. So its gonna cost her $700 instead of $40 with just the joints.
   / 2320 Drive Shaft U Joint blew up. #97
Same thing happened on my 4010, really the same tractor.
The donut thing more or less exploded when I turned the PTO on to the bush hog. Then nothing worked.
I traded it in on the 1025, which proved to be lemon. Than traded that on a 2025, which is near the same as your 2320 and my 4010.
Can't get to that front U joint.
   / 2320 Drive Shaft U Joint blew up. #98
Mine blew today while mowing. My mechanic neighbor came over to show me how to tear it down and make the repair. Looks like parts will be $700. He said it looked like it had never been greased. We had it professionally serviced at 100 and 200 hours. I did the 300 hour service. Nothing in the manual about greasing. Tractor is 9 years old.
   / 2320 Drive Shaft U Joint blew up. #99
If professionally serviced at the dealer, and documented, and you never got the revision about greasing...pressure your dealer for help
   / 2320 Drive Shaft U Joint blew up. #100
Yesterday while servicing my mower I made sure the driveline was greased. Tough to get to but it has to happen.
Leer Camper Shell (A57454)
Leer Camper Shell...
JLG 660SJ (A58216)
JLG 660SJ (A58216)
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
1765 (A58375)
1765 (A58375)
