Oil & Fuel 2305 fuel consumption
   / 2305 fuel consumption #11
Hard said:
JDFAN, I wonder if the steel valve stems like the stems on the 2320 will fit your 2210 wheels. I bet they would, I don't know for sure. It might be worth a call to your dealer to find out.
Hard,
I did ask that today, but I'm told those are for tubed tires. $91 later, I'm back in business.
   / 2305 fuel consumption #12
Good to hear you are back in business.
   / 2305 fuel consumption #13
I have a 2210 and did have a 335 20HP gas. The 335 used 2X the fuel running a 54" deck versus the 62" on the 2210. I have since traded the 335 for a used 355 (20HP diesel) and the v-twin Yanmar in the 355 is just as stingy on fuel as the 2210.
If and when I buy another garden tractor or CUT, diesel is the only engine type I will consider.
   / 2305 fuel consumption #15
My Kubota 7510 uses about .5 gal. per hour mowing lawns at 1300rpm. Rottotilling uses 1 gal per hr. at 2000 rpm.
   / 2305 fuel consumption #16
Towing my 5' RFM at 29??/540 PTO does use about 1.6 gallons an hour. That's bouncing around a rough sloping pasture at about an acre an hour. Some days I take off the bucket and leave the loader frame to bang around a bit. Other days I take it all off and hang suitcase weights.
Poking around with a box blade, rake, FEL, it barely uses any fuel.
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
AUCTION STARTS HERE @ 9AM (A52707)
AUCTION STARTS...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2015 Ford F-450 9ft Flatbed Truck (A55852)
2015 Ford F-450...
Massey Ferguson 9250 (A55315)
Massey Ferguson...
