2240 cold start
   / 2240 cold start
Im going to put power to the barn this week so it will be plugged in from now on. I had a chance to buy a 3020 but I went with the 2240 because it had a loader and the 3020 didnt. I was concerned it was a 3 cyl problem because I have opperated but not owned a 4440 and a few other 6 cyl diesel tractors (IH , oliver) and none of them had any problems when cold. Thanks for all the advice it is greatly appreciated.
   / 2240 cold start #12
The 4 cylinder engines have either a balancer box(3020) or balancer shafts in (Dubuque/Mannheim/Saran) engines that can fail and cause problems
   / 2240 cold start #13
You just need to use the block heater and you will be fine. I thought you where trying to say it still did not start great with the block heater plugged in. I went back and read your post again. I read where it was in a new barn with no electric yet.:)
   / 2240 cold start #14
If you know that you will be using the tractor at a certain time, put a timer on the heater and set it to start a couple hours before you want to use it. Rather than plugging it in full time.
   / 2240 cold start #15
Hello everyone, here in Michigan it is getting colder as I'm sure a lot of you experienced and the snow is immanent. That being said I bought my 2240 earlier this year when it was warm and I am new to the compact and diesel tractor world. This past week it was below freezing (around 25 degrees) and when I start it up it doesn't run smooth, it pops and acts like it wants to idle fast and I haven't touched the throttle and it is set to idle. I am curious if this is caused by the tractor being a 3 cylinder or if there is something going wrong (injectors, injection pump). Now after it warms up for 10 minutes it quits popping and runs like a champ. I should say that the tractor only has 2100 hours on it and the lift pump was replaced once. The tractor doesn't have any glow plugs but it does have a coolant heater and that helps but I put it in a new pole barn without power otherwise I would use it. The tractor isn't hard to start I am just concerned about what is causing the popping action. Thanks and I hope everyone has a good winter.
Find some way to supply power to the block heater.
   / 2240 cold start
The timer is a good idea, I might just try it.
   / 2240 cold start #17
That's what I do with my diesel pick up in the winter. I have it set for a few hours before I need to leave for work. Starts easy and I actually have heat!!! My 05' dodge (5.9 cummins) takes forever to warm up!
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV6NPNJ0431, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
Deere 35P (A53317)
Deere 35P (A53317)
2264 (A58376)
2264 (A58376)
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
