2014 Kioti DK50se starter solenoid
   / 2014 Kioti DK50se starter solenoid
Was there no solenoid available specifically for your model of tractor, or did you do a cross-reference to decide on this one? Or maybe it’s just a WAG?đŸ˜¬
I couldn't locate one. This is a best guess.
   / 2014 Kioti DK50se starter solenoid #13
I thought I had the same problem with mine when I tested voltage. Got full voltage to the starter when I turned the key. So I have a Snap-On pushbutton starter switch, it has heavy cables with alligator clips on the ends. You hook one end up the battery, and the other to the solenoid, put the key in the run position and push the button. It's great for checking starter issues. Well, here I thought it was the starter solenoid, and it's turned out to be the relay after all. I hit the button and it cranks right over.
When you look at the firewall from the front of the tractor, there are three relays on the left side above the gas tank. The starter relay is the one on the left. The one in the middle is the glow plug relay, and the one on the right is the stop relay. I picked up replacements for all three from the dealer, they are pretty cheap, but usually I just tap on the relays when I have an issue and it fires right up.
The one time it didn't, it turned out one of the main fuses was blown for some reason, they are electrical taped to the wiring harness by the starter.
   / 2014 Kioti DK50se starter solenoid #14
Wasn't there also something about the cable corroding from the inside causing starting issues? Seem to remember it being a thing here, but can't remember the models and years affected.
Mine had that issue, the positive lead on the battery looked "good enough", cleaned the battery post, and lead. It would click the solenoid, but as soon as the starter kicked in the solenoid would disengage due to low voltage I guess....
I cut back the insulation on the positive lead and the wire was terrible where it went into the lead. So I cut the wire back to decent copper and put a new lead on, and it works fine for a few years now.
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
