2013 Kawasaki Mule 4010 Trans 4x4 Diesel (KAF950GDF) - Totally Rebuilt - Texas
Item Details
Item status
  1. Sold
Features and Options:
- VIN: JK1AFDG13DB508833 (10th Digit is ‘D’ Indicating 2013 Model
- 1,449 hours / 7,841 miles
- On-Demand Four-Wheel Drive
- Selectable High / Low Range
- Dual Mode / Locking Rear Differential
- Limited Slip Front Differential
- EPS Electric Power Steering (EPS)
- Diesel Three Cylinder Engine
- Automatic via Continuously Variable Belt Drive Transmission
- Dump Bed with Ability to Adjust Size and Load Volume
- 4 seater can convert to 2 seater with larger bed (hence the term ‘Trans’)
- Roof with Tilt Up / Removable Rear Section for Hauling Large Items
- Front Brush Guard
During rebuild, this Mule was taken down to the chassis with the engine / gearbox combo and front axle being the only significant items not removed. Any parts removed from this Mule during the rebuild process were inspected, rebuilt, replaced, and / or repainted prior to re-installation. Entire Mule has been gone over in detail. All fluids flushed, all filters changed, and all defective, missing or worn parts have been addressed.
Listed below are just a few of the new parts installed and / or rebuilt:
- Rear Tires (two (2)); Front Tires have 90% Tread
- Heavy Duty Battery (Rated at 540 CCA / 650CA)
- Aluminum Radiator
- Fuel Filter
- Engine Oil Filter
- Engine Air Filter
- Belt Drive Air Filter
- Taillights Upgraded to Waterproof LED and Custom Mounted
- 12V Dual USB Port Installed in Front Dash
- Engine V Belt
- Any 6mm Phillip Head Machine Screws Removed were Updated to Allen Head
- Any 6mm Phillip Head Self-Tapping Screws Removed were Replaced
- Any Plastic Rivets Removed were Updated to Stronger Design Rivets
- All Fluids Replaced (Engine Oil, Transmission, Front Differential, Brake, and Anti-Freeze)
- Front End Plastic Bed-Liner Coated in Kawasaki Red
- Bed Sides and Tailgate Bed-Liner Coated in Kawasaki Red (Outside and Inside)
- Bed Flooring Bed-Liner Coated in Black
- Front and Rear Fenders Bed-Liner Coated in Black
- Majority of Plastic Side Rails Replaced with New Parts (5 of 6 New)
- Any Other Plastic Components Reconditioned (NOT Repainted)
- Roll Bar Repainted
- Front and Rear Flooring Repainted
- Tailgate Cables Upgraded
- Hood Hinges and Locking Mechanism Upgraded
- Emergency Brake Cable
- Hub Nuts, Lock Washers, and Washers (see images)
- All Brake Pads have 90% Remaining with Internal Components Recently Replaced (see images)
- Front Brake Hubs Appear Recently Replaced
- Radiator Fan Rebuilt (see images)
I have included images of the Kawasaki Red Bed-Liner Coating shown on the front grill (blue tape over headlights as they have been polished), several bed side panels and hood. The black Bed-Liner used on the fenders and inside front trunk isn’t as aggressive looking as the red Bed-Liner. It will still provide protection while giving a nice subtle contrast.
Once completed, this Mule will be equal to if not better than the Mules being sold today. This Mule will be sold as a complete, running unit with a Bill of Sale identifying factory VIN. You are welcome to view the Mule while it is in the final stages of completion to confirm the effort and level of quality which has gone into the rebuild. Estimated completion date is March 17, 2023.
Final price will be $9,500 which is a fair market price for a rebuild of this magnitude. A dealer would never have gone to this level of effort due to the high labor costs and low profit. Please note the price is subject to change should a significant issue arise. I do not expect to find any surprises as this unit was well maintained and shows a number of recently installed new parts.
Will be updating the images as the rebuild is nearing completion so check back periodically. Given the popularity of these diesel Mules, I do not expect this Mule to be for sale very long. You are welcome to place a $500.00 fully refundable deposit on the Mule to hold it in your name until completion. Upon pickup, the outstanding balance must be paid before the Mule will leave. I am not interested in trades nor do I offer payment plans. I am a private individual who rebuilds Mule 4010 Trans 4x4 diesel models. Feel free to contact me with any questions or comments.
   / 2013 Kawasaki Mule 4010 Trans 4x4 Diesel (KAF950GDF) - Totally Rebuilt - Texas #2
Where are you located?
Blue Ridge, TX 75424. Sorry for the delay. I did not have notifications set up for this site.
The Mule is complete and below are updated images. Below the images is the updated text.
- VIN: JK1AFDG13DB508833 (10th Digit is ‘D’ Indicating 2013 Model)
- Cargo Dump Bed with Ability to Adjust Size and Load Volume
- 6 seater can convert to 3 seater with larger bed (hence the term ‘Trans’)
- Full Roof with Tilt Up / Removable Rear Section for Hauling Large Items
- Front Brush Guard
During rebuild, this Mule was taken down to the chassis with the engine, front and rear axle being the only significant items not removed. Any parts removed from this Mule during the rebuild process were inspected, rebuilt, replaced, and / or repainted prior to re-installation. Entire Mule has been gone over in detail. All fluids flushed, all filters changed, and all defective, missing or worn parts have been addressed.
Listed below are new parts installed and / or upgrades made:
- New Rear Tires; Front Tires have 90% Tread
- New Heavy Duty Battery (Rated at 540 CCA / 650CA)
- New Radiator
- New Glow Plugs (3) - NGK 92785
- Inspected / Rebuilt Starter Motor
- New Fuel Filter
- New Engine Oil Filter - WIX 51394
- New Engine Air Filter - WIX 46449
- Air Cleaner Housing and Seal Upgraded
- New Belt Drive Air Filter
- Rear Wiring Harness Rebuilt
- New 12V Dual USB Port Installed in Front Dash
- New Engine V Belt - Gates 1370
- New Emergency Brake Cable
- New Hub Nuts, Lock Washers, and Washers
- 557 page Service Manual Included (PDF file)
The black Bed-Liner used on the fenders, inside front storage area and cargo bed isn’t as an aggressive texture as the red Bed-Liner. It will still provide protection while giving a nice subtle contrast.
This Mule is equal to if not better than the ‘plastic’ Mules being sold today. Final price of $9,500 is a fair market price for a rebuild of this magnitude. A dealer would never have gone to this level of effort due to the high labor costs and low profit.
Given the popularity of the 4010 Trans 4x4 diesel Mules, I do not expect this Mule to be for sale very long. I am not interested in trades nor do I offer payment plans. I am a private individual who enjoys rebuilding Mule 4010 Trans 4x4 diesel models. Feel free to contact me with any questions or comments.
   / 2013 Kawasaki Mule 4010 Trans 4x4 Diesel (KAF950GDF) - Totally Rebuilt - Texas #5
Daaaaang. If you were local, I would have a hard time resisting. Good as new for half the price!
   / 2013 Kawasaki Mule 4010 Trans 4x4 Diesel (KAF950GDF) - Totally Rebuilt - Texas #6
Good job!
Thank you for all the positive comments. I enjoy rebuilding these Mules.
   / 2013 Kawasaki Mule 4010 Trans 4x4 Diesel (KAF950GDF) - Totally Rebuilt - Texas #8
She's a beauty with the Kawasaki Red Bed Coating.
Engine Specifications
While the engine is stamped ‘Kawasaki Heavy Industries’, Daihatsu was the diesel engine supplier for Mules beginning on or around 2000 in the Mule 2510. The 4010 diesel Mule is powered by a 950cc, water-cooled, three-cylinder, four-stroke Daihatsu DM950D diesel engine rated at 24.5 horsepower at 3,600 rpm. The early Daihatsu diesel model DM950D engines did have some issues, primarily found in the Mule 3010. These issues were poor crankshaft and rod design along with occasional overheating. By the time the 4010 Diesel Mules were put into production, 2009 model year, those issues had been addressed. In other words, if buying a diesel Mule, only buy the 4010 made from 2009 - 2013 in diesel format to avoid the potential issues noted above.
Now before everyone starts whining a sending shots of their 3010 hour meter showing 8,000 'without an issue', the three above 'problems' with earlier diesel Mules, pre-2009, is public knowledge and is even noted by Kawasaki in several internal and external Technical Bulletins. Do I have copies of these bulletins...No. Am I going to hunt them down to satisfy non-believers...No. GOYA, do the research and you will find my statements are correct. Sorry for the tangent, just wanted to nip alternating comments early.
For your further reading enjoyment.
Drivetrain Specs
Power is delivered to the wheels by a continually variable belt-drive transmission with on-demand, four-wheel drive. It offers a selectable high/low range for increased traction. A dual-mode differential drove the rear axle and a limited-slip differential was installed up front.
Dimensions
4010 Diesel Mules weighed 1,750 lbs. and were 128 inches long and 58 inches wide with a 7 inch ground clearance. Wheelbase was 85 inches. The 4010 Diesel Mule has a hauling capacity of 700 - 1,100 lbs. and a 1,500+ lb. towing capacity. Top speed of the Mule is limited by a governor to 25 mph.
