weavertg14543
- Joined
- Aug 17, 2017
- Messages
- 47
- Location
- rush,ny
- Tractor
- john Deere gator 6x4 ferris pro cut s 61 inch 67 cub cadet Kubota ls3130
So had a problem with my rototiller last year. The gas was running out of the carb.
This year tore it apart rebuilt the carb. Was leaking out of the top and down the air filer. Figured the needle valve was the problem. Fired it up ran great no problems then it shut off.
Messed arou d with the carb again. Decided for 15 bucks i would put a new one on Nd call it good.
Same problem. Gas fill up in the bowl and comes out the front by the choke and pours onto the ground. If i drain the bowl it will start and run for 10 feet then boggs down amd shuts off. Will start again but wont stay running.
I took the catb off to see if the float needed to be adjusted it didnt as it was 1 piece plastic.
I would take it to the repair shop but they are three weeks out amd i need it for weeding the ridiculous garden i put in this year. 125x160
Any help would be amazing
