200cx loader slow lift
   / 200cx loader slow lift #1
Rwlight
Louisa, Virginia
2305 john deere
Everything else works fine, bucket roll and lift down...but goes very slow when I try to lift it up....any thoughts?
   / 200cx loader slow lift #2
Welcome to the forum. :welcome:
I'm going to move your thread on over to the John Deere section to see if we can get you some help.
   / 200cx loader slow lift #3
Welcome,
Try unplugging, cleaning, then reconnecting the 4 hydraulic quick-disconnects (QD's), this fixes 90% of all "my loader won't xxx" problems. The other 10% are bad QD's.
   / 200cx loader slow lift #4
Do you have a lock lever just below your seat that might have shifted over?
   / 200cx loader slow lift #5
A buddy has the same tractor that I have used a few times. The loader in it is slow. The tractor only produces 2.9 GPM. It just isn't going to be very fast.
   / 200cx loader slow lift #6
4570
Not sure how you know the tractor the FEL is on, as it wasn't mentioned. Or where the 2.9 GPM came from?
   / 200cx loader slow lift #7
4570 Not sure how you know the tractor the FEL is on, as it wasn't mentioned. Or where the 2.9 GPM came from?
His profile says a JD 2305. 2.9 GPM is a published spec.
   / 200cx loader slow lift #8
Sorry, I missed that.. ;)
   / 200cx loader slow lift #9
Even still, he is complaining about only ONE function being slow, not everything.
   / 200cx loader slow lift #10
JD should have published the time required to lift to fill height at a given rpm. Should be pretty easy to check if it works correctly.
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
Year: 2000 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 183122.9 Plate: Body Type: 4 (A53422)
Year: 2000 Make...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Fimco 25 Gallon Sprayer (A50123)
Fimco 25 Gallon...
