200cx loader slow lift
   / 200cx loader slow lift #1
Rwlight
Louisa, Virginia
2305 john deere
Everything else works fine, bucket roll and lift down...but goes very slow when I try to lift it up....any thoughts?
   / 200cx loader slow lift #2
Welcome to the forum. :welcome:
I'm going to move your thread on over to the John Deere section to see if we can get you some help.
   / 200cx loader slow lift #3
Welcome,
Try unplugging, cleaning, then reconnecting the 4 hydraulic quick-disconnects (QD's), this fixes 90% of all "my loader won't xxx" problems. The other 10% are bad QD's.
   / 200cx loader slow lift #4
Do you have a lock lever just below your seat that might have shifted over?
   / 200cx loader slow lift #5
A buddy has the same tractor that I have used a few times. The loader in it is slow. The tractor only produces 2.9 GPM. It just isn't going to be very fast.
   / 200cx loader slow lift #6
4570
Not sure how you know the tractor the FEL is on, as it wasn't mentioned. Or where the 2.9 GPM came from?
   / 200cx loader slow lift #7
4570 Not sure how you know the tractor the FEL is on, as it wasn't mentioned. Or where the 2.9 GPM came from?
His profile says a JD 2305. 2.9 GPM is a published spec.
   / 200cx loader slow lift #8
Sorry, I missed that.. ;)
   / 200cx loader slow lift #9
Even still, he is complaining about only ONE function being slow, not everything.
   / 200cx loader slow lift #10
JD should have published the time required to lift to fill height at a given rpm. Should be pretty easy to check if it works correctly.
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
