200cx loader slow lift
   / 200cx loader slow lift #1
Rwlight
Louisa, Virginia
2305 john deere
Everything else works fine, bucket roll and lift down...but goes very slow when I try to lift it up....any thoughts?
   / 200cx loader slow lift #2
Welcome to the forum. :welcome:
I'm going to move your thread on over to the John Deere section to see if we can get you some help.
   / 200cx loader slow lift #3
Welcome,
Try unplugging, cleaning, then reconnecting the 4 hydraulic quick-disconnects (QD's), this fixes 90% of all "my loader won't xxx" problems. The other 10% are bad QD's.
   / 200cx loader slow lift #4
Do you have a lock lever just below your seat that might have shifted over?
   / 200cx loader slow lift #5
A buddy has the same tractor that I have used a few times. The loader in it is slow. The tractor only produces 2.9 GPM. It just isn't going to be very fast.
   / 200cx loader slow lift #6
4570
Not sure how you know the tractor the FEL is on, as it wasn't mentioned. Or where the 2.9 GPM came from?
   / 200cx loader slow lift #7
4570 Not sure how you know the tractor the FEL is on, as it wasn't mentioned. Or where the 2.9 GPM came from?
His profile says a JD 2305. 2.9 GPM is a published spec.
   / 200cx loader slow lift #8
Sorry, I missed that.. ;)
   / 200cx loader slow lift #9
Even still, he is complaining about only ONE function being slow, not everything.
   / 200cx loader slow lift #10
JD should have published the time required to lift to fill height at a given rpm. Should be pretty easy to check if it works correctly.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Ruger Shop Crane, 2,000lb Capacity (A52384)
Ruger Shop Crane...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
CAT 973 (A47384)
CAT 973 (A47384)
378813 (A51573)
378813 (A51573)
