2006 4320 front wheel seals leaking
   / 2006 4320 front wheel seals leaking #31
Just a follow up, I changed the fluid in my front axle. The oil that drained out looked good but dark colored. I could not notice any moisture / cloudiness. All set for another 600 hrs. It's been to cold to warm up the front axle, but the tractor was inside a heated garage. I drained the oil for about an hour and also used and air hose to force out any remaining oil. Later
That’s great news, @logcabin ! That will save a ton of money given that all works well for you. I look forward to hearing your results when you return from Montana - have a nice trip to see your daughter!
Well, sorry for the delay but here goes. Putting the caps in, at least for me was no easy task. As mentioned earlier they have to go in straight. I didn't have a large enough socket to encompass the entire cap so I used a 3/4" socket which set on the flat spot of the cap. The problem was, on my back, holding the socket and now I have to tap it. Try tapping it with two months prior total shoulder replacement. Needless to say that was a NO GO!. I mentioned earlier about using a bottle jack. Had to remove tires to get jack in the proper position. I went to auto store to look for a socket. cheaper than having the delaer do it I guess. I found a 65-67 mm oil wrench which fit the inner part of the outter edge of the cap. Perfect! Everey time I got what I thought was perfect to push up in housing, it seemed to not push straight. Quite frankly it was pissen me off!. I went back the next day to try again. Same thing so I pushed anyway with the bottle jack. It went in really slick but just wasn't setting like it should. I took a hammer and gave it a tap. That sucker bottomed out perfectly! Damn, it worked. Did the same thing to the other side. It worked again. Speaking with a JD mehanic he suggested to use a dab of red or black gasket maker to give a litte extra protection. I had a tube of "seals all" which is rated for -40 - +150 F. Good for gas and oil on the package. I just put a dab on the outter edge of the cap all the way around. I attached a photo taked today. 2/14/25. The photo is two days after putting in the caps, refilling and pushing snow 5 or 6 hours. At this point all appears normal. I want to once again say THANK YOU to everyone that took time to write something that pointed me in the right direction. Every single input help me, it truly did!!!
In South Bend Indiana we ran into some nasty conditions. I have never driven in a "TOTAL WHITEOUT" until then. The only way you could remotely tell where the vehicle was, I straddled the rumble strip on the right side. For 2 to 3 seconds you have total blindness, but we made it! We had a safe trip, got to spend some time with our daughter, had a safe return trip, and tractor seems good. I thank you all agian! Be, well, be safe, and be happy!
   / 2006 4320 front wheel seals leaking #33
Sounds like a heck of a time…. But at least you got it done and in. My front axle is working like charm so I’m very happy with everything. Together with solving the gel’ing issue that we had when we hit 35 below a month back (darn fuel filter mushed up), things have been good.
Whiteout’s suck. I had that happen coming back across I-90 in South Dakota last winter after picking up a dog in Idaho. Fortunately for us, it all went well - but there quite a few semis that didn’t fare as well. Glad you made it!
Thank you my friend. You drove from MN to Idaho to pick up a dog? Rescue? I may be going to Texas to pick up one if she cannot find a fantastic home. It has got to be the perfect home or I am heading to Texas. Guess we do have a lot in common. haha. Now, if only I could fix my damn knee.
   / 2006 4320 front wheel seals leaking #35
Actually, we went to Idaho to bring back a Puppy that my daughter bought. It was a great family trip going out there.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2005 John Deere 330CL (A55272)
2005 John Deere...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
14179 (A55788)
14179 (A55788)
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2015 Peterbilt 348 VacCon Combination Sewer Jetter Vacuum Truck (A55973)
2015 Peterbilt 348...
