1978 Case 580C power shuttle forward clutch piston
   / 1978 Case 580C power shuttle forward clutch piston #1
ewbaxter
Penn Yan, NY
Case 580C
Hi Folks,
Here is a newbie question. I am doing a rebuild on a 1978 Case 580C shuttle transmission due to slipping/not moving in forward. I have the service manual and have been following the disassembly steps. Everything was going fine right up to the point where I am supposed to remove the forward clutch cylinder and piston assembly from the ring gear. I have removed the retaining ring but I can't seem to get the cylinder out of the ring gear. The manual says this is a light press fit but I can't seem to press or drive the cylinder out. I am trying to be careful since a new ring gear isn't cheap. I have tried to drive the cylinder out from the bottom (the side opposite the clutch spring). Am I missing some key trick? Thanks for any help you might have.
Eric
   / 1978 Case 580C power shuttle forward clutch piston #2
Is it possible to try a little heat or dry ice, as appropriate?
Hi Bob,
I will try the dry ice, I was a little hesitant to use heat, replacing the ring gear is an 800 dollar proposition.
Thanks,
Eric
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2000 Ford F650 Flatbed TMA (A49461)
2000 Ford F650...
1042 (A50459)
1042 (A50459)
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
