1920 sooted up
   / 1920 sooted up #1
Twindad01
Bronze Member
New Brighton PA
1990 new holland 1920
So took the exhaust manifold off and it was almost clogged off on most of the ports and really packed in the head part. Any idea what would cause this? My theory is it was bogged down a lot. My buddy says not running hot enough and wants to up the thermostat to a 195. Any and all ideas are most welcome
   / 1920 sooted up #2
Possible valve stem seals are leaking oil. Is it dry soot or wet/damp soot. Also could be excessive over fueling or a lot of idling time. How much blow-by does the engine have. A lot moisture getting into the exhaust from rain or setting in an excessive damp environment.
   / 1920 sooted up #3
Change your oil recently? Even new oil with a high ash level will form deposits in the exhaust manifold
   / 1920 sooted up
The soot seemed to be somewhat wet. Cant say about the oil change as it hasn't really been ran since we got it. Now it's torn down and going back together. It has 1160 hours on it.
   / 1920 sooted up #5
Once running again, I would check for deposits every 25 hours or so, limit idle time to a minimum, and keep the rpm's up while running.
   / 1920 sooted up #6
It's not being worked hard enough. You might also check the sir filter and see if it's clogged. That will make the fuel/air ratio too high and contribute to the problem.
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55315)
BOSS 990 Fuel...
2002 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2002 Ford F-250...
UNUSED PABREAK RGB240 - 84" ROCK GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
John Deere 520M Loader (A53317)
John Deere 520M...
CFG Industrial MX15RX (A56469)
CFG Industrial...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
