155 Sluge from exhaust Why?
   / 155 Sluge from exhaust Why? #21
Gee, that looks like the chocolate pudding I just had for dessert today after Easter dinner. Bet my pudding smelled better...lol Never had that issue but I use PS Bio-Kleen.
   / 155 Sluge from exhaust Why? #22
BIo Kleen. That easter egg Chocolate pudding is rough! Runs Instant a bowl full, Glad I don't see a Pic.! :oops:
   / 155 Sluge from exhaust Why? #23
Check the thermostat for proper operation it very important that the engine gets up to temperature.
If the radiator gets warm as soon as the engine is started the thermostat may be bad.
Top of radiator should be hotter than bottom by a significant amount.
It can be difficult to get the engine up to temperature without a decent load which varies according to horse power. A ground engaging attachment will place a load on the engine.
If you had a tractor driven generator (PTO) that would be the perfect way to apply a constant load for a1/2 hour or more.
Mowing, tilling & pulling a box scraper will also work the engine.
90cummins
   / 155 Sluge from exhaust Why? #24
Not 100% sure but I'm not showing one for a 155. What I do show
HT-9350 160. Deg. To many to list them all But No Thermostat.
   / 155 Sluge from exhaust Why? #26
Radiator RA-4060 135,155,165,1100,1300
No Water pump I'm showing WP-4201 169,180,186,220 226, and may more that has a water pump.
   / 155 Sluge from exhaust Why? #27
My y YM 1700B had a similar issue when I used it, but not when my son was putting in deer plots. Finally figured out I was running around 1500 RPM for short periods but he was running 2200 RPM for prolonged periods. I started working the 1700 harder and the problem disappeared.
   / 155 Sluge from exhaust Why? #28
My YM 1700B had a similar issue when I used it, but not when my son was putting in deer plots. Finally figured out I was running around 1500 RPM for short periods but he was running 2200 RPM for prolonged periods. I started working the 1700 harder and the problem disappeared.
Me too, but not as severe.
When I bought the second YM186D, this current one with a loader, the seller said it must have worn valve guides causing the clouds of smoke upon starting and when throttled up. This has cleared up over the years I've owned it.
Apparently the prior use by an urban landscape contractor didn't work it very hard. Likely 30 years of put-putting around at low rpm.
   / 155 Sluge from exhaust Why? #29
On the 1700 even a B should not have a water pump. My guess the Thermal Sys. works better at a higher RPM's than put putting around. I believe one of the main reasons they went to a water pump cooling Sys. JMO... and something to consider if that's true.
My Org. YM2000 it was the muffler I had trouble keeping clean. After I finally did remove and clean it. I don't have much of any smoke or buildup on the cap!
   / 155 Sluge from exhaust Why? #30
Actually the B did come with a water pump. Also a dash pod, upgraded side panels and different headlight bezels. I guess like the difference between a Ford and Mercury. Same platform with some upgrades.
Ratchet Straps (A55852)
Ratchet Straps...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57192)
KNOW BEFORE YOU...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
