15 ft finish mower. Anyone own one of these?
   / 15 ft finish mower. Anyone own one of these? #11
BTW, not sure what kind of deck wheels come on those things now but I had mine foam filled after I got it. Best thing in the world to do. Or get solid wheels.
   / 15 ft finish mower. Anyone own one of these? #12
Not a Batwing, but I have mowed with a 7' Befco finish mower for the past 15 years or so. Very well made mower.
I bought it with solid tires and bought air tires shortly thereafter... Big mistake imho, as I had constant flats.
   / 15 ft finish mower. Anyone own one of these? #13
I use a Woods 12 ft. batwing finish mower. I bought it used from the neighbor when they moved. They stored it outside and some of the moving parts were seized with rust. I got everything moving freely and replaced some of the gearbox seals and it works good now. i mow about 4 acres of lawn and 6 acres of horse pasture. I mow the pasture once a year at the highest position and it works my NH 3040. If you get one, I would store it inside as there are a lot of moving parts.
View attachment 680006View attachment 680007
I wish there was a way to setup one of these 12 foot finish mowers so the cut height range was like say 2 and half inches to 8 inches. I like to cut our pastures higher to leave grass for grazing.
   / 15 ft finish mower. Anyone own one of these? #14
When I was still working, we sold many of the BushHog TDM series multiple deck finish mowers, lots of golf courses and city parts used them. You cover tons of ground in a hurry with one, just remember that痴 it痴 3 times the belts, idlers, tires, and blades, can get expensive, however they do mow well and other than finding a place to keep it out of the sun and weather I can稚 think of a negative if you have that much grass, (remember, this is not a pasture mower)
   / 15 ft finish mower. Anyone own one of these? #15
I believe the highest mine will go is about 6". Spacers are used for adjustments at the caster wheels.
   / 15 ft finish mower. Anyone own one of these? #16
Yes 5 or 6 inches is the max I have seen.
The other issue is once all those spacers are added to cut high, it looks like the spindles would be easy to bend/damage.
Step, I have that same mower in a 20 foot version. Mine is a Befco branded Frontier. I bought it used several years ago and have had zero issues with it once I got the couple of things that were wrong with it squared away. When I bought it I was pulling it with my old JD 5310 but have since upgraded to a 5090. Mine had the manual deck release and now with a cab I need to add the hydraulic deck release but I'm not able to find it anywhere as an add on. I often times say that this is in the top 5 of best things I ever bought. Had I been relegated to buying it new I probably wouldn't own one because of the price but knowing what I know now I would. I couldn't function without mine.
Good job... That is what I wanted to hear. The one I found is 15ft, probably would mow my 30 acres in 4 to 6 hours.
Well, my pastures are very clean, rolling orchard grasses. No rocks or soil mounds. I figure it will be more like 30 acres of lawn, as we don't graze animals or hay. Don't ask... wifey likes it mowed...
   / 15 ft finish mower. Anyone own one of these? #19
I've seen the Frontier version.
This one has a neat work around for no rear hydraulics. They just put a 12V pump assembly on it and ran some wires.
   / 15 ft finish mower. Anyone own one of these? #20
I’ve got a Progressive TD-65, I pull it with a Kubota L6060. I bought two of them and a skid load of parts from a local sod farm that closed. I kept one and the parts. It works great and has been very reliable, but I like the fact that there isn’t anything on it that couldn’t be sourced locally or homemade.
I grease it regularly and replaced a valve stem in a pneumatic caster. Haven’t changed a belt yet, but I’ve got spares.
Cut quality is excellent. I’m sure that the woods, LP or Befco are all similar quality.
M&W PT407 4 Basket Hay Tedder (A56469)
M&W PT407 4 Basket...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
Sundowner Rancher Express 20FT Livestock Trailer (A55315)
Sundowner Rancher...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
2020 Peterbilt 367 (A55973)
2020 Peterbilt 367...
