15 ft finish mower. Anyone own one of these?
   / 15 ft finish mower. Anyone own one of these? #2
We've got a couple of Woods BW240 mowers here at work we tow behind a New Holland TV140. A bigger version of what you're looking at but the same thing pretty much. We use them for mowing the median which is very rough and lots of rocks and debris.
The first couple we bought only lasted a couple of years thru no fault of the mower, they just weren't made for mowing over that kind of a rough debris covered surface. The top of the deck ended up getting cut in numerous spots as well as the perimeter of the deck was battle scarred and cut quite bad..
Next one we bought we got the ring underneath which made a world of difference as it stopped the blades being driven up into the underside of the deck. Other than that we've had no major problems with them.
We ended up going with the foam filled tires as the pneumatic ones were constantly going flat.
The decks on ours were gravity down, on any kind of a sloped surface, the deck on the uphill side wouldn't drop as it was past center. We ended up modifying the hydraulics to pressure it down and then a float position when being used so it would follow the terrain
If you're mowing a field I can't see you having any problem........Mike
I watched a few video's of the mower you are referencing; they are more of a bush hog blade than a finish mower. Lot's more money as well.
   / 15 ft finish mower. Anyone own one of these? #4
I had a 15 ft Woods batwing mower. Used the Kubota M7040 to pull it and maintained 3 to 4 miles per hour when mowing. It can cut a lot of grass in a short period of time. I think a smaller tractor maybe 30 to 40 hp will pull it as well. No problems with it. Had it hooked up to raise one deck at a time with 3 remotes although the PTO has to be off to do that. Sold it when we planted 6000 trees and our needs changed to Zero turn mower Kubota ZD331
Interesting... I do have a ZD 331 myself, and that is hard times mowing 30 acres... hence the bat wing option. I'm looking for that option where I don't spend all of my golden years mowing grass.... BTW, looks like you are a fellow Kubota man. :thumbsup:
   / 15 ft finish mower. Anyone own one of these? #6
Yes a Kubota owner for sure. Latest additions were the minix and new RTVX1100. The batwing 15 ft is what you need for 30 acres and if you have a cab tractor with air suspension seat you are golden
   / 15 ft finish mower. Anyone own one of these? #7
A buddy of mine has the Land Pride equivalent of that mower. He uses it on 60 acres of CRP land.
   / 15 ft finish mower. Anyone own one of these? #8
Are ya going for a golf course Wolf? :)
   / 15 ft finish mower. Anyone own one of these? #9
I use a Woods 12 ft. batwing finish mower. I bought it used from the neighbor when they moved. They stored it outside and some of the moving parts were seized with rust. I got everything moving freely and replaced some of the gearbox seals and it works good now. i mow about 4 acres of lawn and 6 acres of horse pasture. I mow the pasture once a year at the highest position and it works my NH 3040. If you get one, I would store it inside as there are a lot of moving parts.
   / 15 ft finish mower. Anyone own one of these? #10
Step, I have that same mower in a 20 foot version. Mine is a Befco branded Frontier. I bought it used several years ago and have had zero issues with it once I got the couple of things that were wrong with it squared away. When I bought it I was pulling it with my old JD 5310 but have since upgraded to a 5090. Mine had the manual deck release and now with a cab I need to add the hydraulic deck release but I'm not able to find it anywhere as an add on. I often times say that this is in the top 5 of best things I ever bought. Had I been relegated to buying it new I probably wouldn't own one because of the price but knowing what I know now I would. I couldn't function without mine.
2019 BOBCAT T450 SKID STEER (A52707)
2019 BOBCAT T450...
Case Titan 3530 (A57024)
Case Titan 3530...
DIRT DOG RC105 5' ROTARY MOWER (A57192)
DIRT DOG RC105 5'...
Bering LD15 Cab with Engine and Transmission (A55852)
Bering LD15 Cab...
60" MOWER DECK SHELL (A57192)
60" MOWER DECK...
2025 Newrick JC25 Mini Wheel Loader Skid Steer (A55851)
2025 Newrick JC25...
