1430 8 hour maintenance questions
   / 1430 8 hour maintenance questions #11
MossRoad said:
That's funny because they told me to use white lithium grease. :p
I've used white lit spray since day one and no problems.
   / 1430 8 hour maintenance questions #12
Some lubricants do not mix well, so if you want to change lubricants, clean out the old and in with the new.
Dry lube will not collect as much dirt, while white lithium will. With white lithium, you can see where the grease is.
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
(10) 24' CORRAL PANELS W/ (1) 8' GATE (A57192)
(10) 24' CORRAL...
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
BROWN TC0-2620C 6 1/2' TREE CUTTER (A57192)
BROWN TC0-2620C 6...
HOMEMADE 6' X 16' DOUBLE AXLE UTILITY TRAILER (A57192)
HOMEMADE 6' X 16'...
