1211 No Spark
   / 1211 No Spark #1
makoshako
Hello All ... we have a 1211 with a Kohler motor that is used infrequently since we have a zero turn now ... the tractor always started (if you keep the battery charged), but one day it would not. I tried the usual things (getting gas, safety circuits) and then finally checked the spark. No Spark. I double checked the "Engine Off" safety switch that I knew of and all of them seemed fine.
Which safety circuits effect the ignition? Is there an electrical diagram out there somewhere? What ignition components could cause no spark.
Thanks in advance!
   / 1211 No Spark #2
Not sure if you found your answer but you should check your coil wire that's what was wrong with my 149 when I got it . It had a bare spot and was grounding out .
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2013 Ford F-550 Ambulance (A50323)
2013 Ford F-550...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
