10 Hour Oil/Hydro Change
   / 10 Hour Oil/Hydro Change #11
Has anyone tried to extend the drain tube with more pipe; permanently bringing it to the end of the frame?
It's location is /forums/images/graemlins/crazy.gif
   / 10 Hour Oil/Hydro Change #12
My 2185 is set up in this manner also and it's a 96 year model (I think). The included hose was useless. I've always been able to park it with the front left tilted slightly lower and let it go. With a large drain pan and the help of a piece of cardboard the mess isn't too bad. Just be sure to have a few paper towels to wipe down the section of frame next to the drain plug. This was an engineering after-thought that should have been corrected long ago.
   / 10 Hour Oil/Hydro Change #13
</font><font color="blue" class="small">( Has anyone tried to extend the drain tube with more pipe; permanently bringing it to the end of the frame?
It's location is /forums/images/graemlins/crazy.gif )</font>
Nope. You cant on the 2544 unless you want to lift the engine to remove and replace the factory installed oil drain valve. The best idea i've seen yet utilizing the existing drain, is to buy a section of super flexible surgical tubing (home depot or lowes). That type of tubing flexes and bends without pinching off. Someone else cut a hole thru the frame crossmember right under the drain to give the hose an easy route.
Joel
   / 10 Hour Oil/Hydro Change #14
On the '06, Cub added a 90 degree pipe bend and now the oil drain run parallel with the frame. It looks like you would have room to attach the hose to drain the old oil.
   / 10 Hour Oil/Hydro Change #15
</font><font color="blue" class="small">( On the '06, Cub added a 90 degree pipe bend and now the oil drain run parallel with the frame. It looks like you would have room to attach the hose to drain the old oil.
)</font>
That's the way my 3240 is set up.......much better. You can actually use the supplied plastic hose.
   / 10 Hour Oil/Hydro Change #16
</font><font color="blue" class="small">( On the '06, Cub added a 90 degree pipe bend and now the oil drain run parallel with the frame. It looks like you would have room to attach the hose to drain the old oil. )</font>
That's a definate plus. Leaving it the way they did for 2005 was rediculous.
Joel
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2005 EZ-GO Cart (A55853)
2005 EZ-GO Cart...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55314)
2022 Brush Wolf...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
