RedNeckRacin
Elite Member
- Joined
- Jan 6, 2008
- Messages
- 2,506
- Location
- Western PA
- Tractor
- John Deere 5083E MFWD, Kubota L3400 HST
I have an MX10 3pt on some pretty serious hills in pa. I have cut 4-5' tall grass (over the top of the rear tires) and it was slow going/burnt alot of fuel with 69pto hp. 3pt is absolutely outta the question, my hydraulics do it but its very noticeable and not fun to road with the rear tires on the mower off the ground. A semi mount would also most likely be out of the question as well since it will be a cat2 pin I would assume. If you can find a trail behind it MIGHT work ok. I'd suggest borrowing/renting it to try it if your dead set on it. You never know, if its thin grass it may work out splendidly. I would be extremely leery of dragging it around on any hills or soft areas. I would make sure you have as much weight on the front of your machine as you could to offset the heavy tongue load I'm sure a mower of that size is going to have. (assuming a long tongue for making tighter turns with a larger tractor)
I might also suggest mowing it a time or two with your 6 footer to make sure there are no hidden suprises to cause some serious problems. Might also want to budget for a pto clutch repair in the purchase decision.
