Rotary Cutter 10’ dual spindle rotary mower
   / 10’ dual spindle rotary mower #1
930ck
southcentral kansas
allis d 17/ case 930, 1370/ kubota L5740
Looking at a pull type 10’ dual spindle mower and was wondering if that style takes out grass that has been ran over by the tractor better than the 6’ I have now. Seems like after overlapping to re mow what was laid down I am only mowing 4’ .
Have a 50 pto hp tractor so should have enough to use it. Would there be other issues with that style of mower?
   / 10’ dual spindle rotary mower #2
It absolutely will now much better. Higher blade tip speed. Take a good look at Rhino mowers. Excellent quality
   / 10’ dual spindle rotary mower #3
Wouldn't a 6' single spindle have a higher blade tip speed than a 10' dual spindle?
I used to have a mounted JD1008 dual spindle 10ft cutter. If you controlled your speed it cut the tire marks pretty well. Not completely though. So not sure what you expect?
I now use a JD1508 batwing 15ft cutter. So same blade length and assume blade tip speed. I use it to cut my roadbanks. I have it set pretty short and I go slow. It does a good job with the tire marks but you can still see them.
In tall grass the right tire lays it down and the blade can’t get to it , figured with a pull type twin the blades would be further back and what had been driven over would be double cut from two different directions.
   / 10’ dual spindle rotary mower #5
Makes sense.
Mower ended up being in rougher shape in person so will keep looking
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
2013 MACK GU713 (A50854)
2013 MACK GU713...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
