Anyone ever use freeze protection valves?
   / Anyone ever use freeze protection valves? #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I was at the new place today and started looking at freeze protection, with some cold weather in the forecast.
Has anyone used freeze protection valves? The house has 4 outdoor sillcocks (all the freeze proof variety) and I just put the standard foam covers on them. But there're two other spots that give me concern:
  1. There's a hot/cold freeze proof sillcock (I didn't even know they made a hot/cold option), mounted near the hot tub, on a stand-alone patio wall (unheated wall). I don't know how that line wouldn't be at risk of freezing. It's routed on the backside of a wall that has the outdoor fireplace, with no connection to heated space. I'm thinking I should put one of these on both the hot and cold. Freeze Mizer Valve
  2. In the shop, they have some lines that come up from the slab and then run about 12' to a bathroom. I can put a milkhouse heater in the bathroom, but the other parts of this line run through the unheated shop. I'm thinking of cutting in a tee on the lines and put this style of freeze protection valve on them. The discharge could be routed outdoors or into a bucket.Freeze Protection Valve
Anyone have any experience with freeze protection valves?
   / Anyone ever use freeze protection valves? #2
For the livestock, the outside spigot is an frost-free draining type. And if it gets too cold in the negatives, I have 14-inches of copper for this spigot on the inside with an electric heating mesh device to thaw it out. End to end, its about 22 inches.
   / Anyone ever use freeze protection valves? #3
I am struck by how cold it can get down by Dallas as compared to Western Washington. Your low temps can be colder than ours even tough we are at the same latitude as North Dakota. The Pacific Ocean has a considerable effect on temps.
   / Anyone ever use freeze protection valves? #4
After a frozen, supposedly frost free outdoor spigot froze and broke in my basement about 8 years ago, and flooded 2 rooms, i removed all my wall mount faucets outdoors and installed ground mount frost frees instead. These are buried 4 foot at makeup.
   / Anyone ever use freeze protection valves? #7
I've never had any of these freeze up. Mine are installed so that the interior part is going into the basement. I did replace the packing in one after about 25 years of use. I also have a couple of yard hydrants but I try to avoid using them in icy conditions because the handle tends to freeze fast and the cheap hydrants I have tend to have problems.
Woodford 1/2 in. MIP in. Sweat Anti-Siphon Brass Freezeless Wall Faucet​
   / Anyone ever use freeze protection valves? #8
I’ve never had one of these types of outdoor taps freeze either. That said, I make sure to remove hoses, etc, in the fall when it gets colder so that water isn’t trapped near the spigot which can cause them to fail.
   / Anyone ever use freeze protection valves? #9
All of my 8 faucets are frost free. Never had an issue with them freezing.
   / Anyone ever use freeze protection valves? #10
This has got me to thinking... it's rough to start nowadays, but I eventually get up to speed.
I'm almost in our new house. It has fully foamed interior insulation - attic & all exterior walls. The wiring and plumbing came after, and all of the pumping except for the fixtures are PEX.
All of my previous houses have had black iron piping and were not all that well insulated, so the heat would conduct along the black iron enough that I never had to worry about spigots freezing.
PEX probably doesn't conduct heat at all, or very little, leaving the spigots to be roughly the same as the outside temperature.
This begs the question as to whether those foam caps would be effective or not. I may have to look into those Freeze Mizers or some such solution.
It doesn't freeze often or for very long down here down here, but like Hurricanes when it does happen it creates a mess you'd rather not deal with, and it's best to plan ahead.
JOHN DEERE GRILL GUARD & MISC PARTS (A52708)
JOHN DEERE GRILL...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
EPPS Powerhouse Pressure Washer (A55973)
EPPS Powerhouse...
TROY BILT GAS POWERED POWER WASHER (A58374)
TROY BILT GAS...
2009 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A58017)
2009 PETERBILT 387...
2013 Case 580 Super N 4x4 Extendahoe Loader Backhoe (A55973)
2013 Case 580...
