Morning all, 49 going to 51 and cloudy, a bit more rain yesterday.
Got the plow moved after cleaning up the leaves that were in it's space.
Then went and aerating the lawn, of course 3/4 of the way through it starting raining, but I kept going, light rain, will need to clean lawn tractor for winter storage once it's dry out. Did mulch up some more leaves too.
Then I found a buck had ripped through a bunch of smaller stakes to rub our Japanese black pine
So went and drilled holes and put in 2 of the 7' steel T-Posts, they already killed our other pine doing this and seem to leave all the mature trees alone, just going for the ones I planted.
Dog walk in town, even overcast there were still quite a few tourists.
Drew - at my old house my neighbor installed the same doorbell as I had, when he tested his, both ours rang. He switched it to a different channel (little switches) and that worked.
Dropped son off at train station, he seems to be doing well and keeping very busy.
More branches down, but not too bad.
Nice setup to the little Wonder Winterdeere, I haven't bothered, but that would save so much time. Going down hill is easy, it's the rough ground up hill that kills me pushing the blower.
Arly, we have a cell booster, it hasn't helped much, it is older 4G/LTE though, maybe the new ones are better.
I move the rounds to the splitter with the tractor/forks and put them on their side to roll over. Then tilt onto the platform when ready, it is a bit of a strain still though.
These were some of the bigger 30"+ rounds, still have quite a few to go.
Be well,
Ground was finally a little softer, but not as water saturated as I would like. Usually get this done in September, but it's been so dry that I need to use a drill and auger to put posts in the ground still.
Still happy with the forks, moved them closer together to move rounds and so far it lifts them all without issue.
Trees getting pretty bare now, with most of the Ash trees down I can see clear through across the valley. This used to be so thick with trees.
