mystery "96" on PMF display screen L4760
   / mystery "96" on PMF display screen L4760 #1
greenie
Can't find any explanation in the owner's manual. The PMF screen displays the percentage of accumulated particles - but to the right of that bar % display there's a 96 which hasn't changed since I bought this used tractor 3 months ago. There are no error codes and my style of use has a regeneration every 25 hours approximately. The mystery 96 remains on the screen. Any idea what this refers to?
   / mystery "96" on PMF display screen L4760 #2
Hard to visualize what you're describing, but you could try disconnecting the battery for a few minutes, or try the reset codes procedure.
Does the DPF bar and indicated percentage change during use, and reset to zero after a Regen?
   / mystery "96" on PMF display screen L4760 #3
Try doing one or two manual regen cycles to see if the number changes.
Yes. the bar and percentage is active and goes to 100%, regenerates and returns to zero.
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
