Tractor Sizing 6' brush hog on a 30Hp tractor
   / 6' brush hog on a 30Hp tractor #1
b3bt459
Caledonia, MI
Kubota
I currently have a very old 5' brush hog that I use with my 30 Hp Kubota L3130. I recently broke the shaft on the brush hog. The repair is likely more than the value of the mower. I'm looking at replacing it with a 6' brush hog. The question is: can the L3130 handle the larger size? I'm of the theory that if I can drive over it, I can cut it down.
   / 6' brush hog on a 30Hp tractor #3
If you want to maneuver around trees etc or raise the cutter going through the rough, you will notice that a 6' is much more weight than a 5'. My NH TC33D (2500 lbs and 28.6 pto hp) could power the 6' but when it came to man handling it, the weight was an issue.
   / 6' brush hog on a 30Hp tractor #4
If you mow on uneven ground or slopes consider the extra weight of the 6 ft rotary cutter. There will be a significant tail wagging the dog effect. Good luck with your choice.
   / 6' brush hog on a 30Hp tractor #5
yes to above, it's more about tractor weight than pto hp. if you're on slopes & areas where you need to raise the 3ph, you'll certainly notice the extra weight. you can put ballast in FEL & load rear tires w/fluid to help
sometimes the tail wags the dog as mwayne mentions above. check your owners manual re: max implement weight on 3ph. this is a compact tractor forum, & the subject of stressing a small tractor with tasks & implements beyond it's means is a common subject here. keeping in mind safety is the primary concern
good luck in your choice.
   / 6' brush hog on a 30Hp tractor #6
^check your owner's manual for Kubota's recommendation. If you have thick/tall vegetation, 6' may be too much for 30hp without having to slow to a crawl.
   / 6' brush hog on a 30Hp tractor #7
I see that as part of the problem, he doesn't have 30 hp. at the pto.
The L3130 with a hydro tranny has 24 pto hp.
Geared tranny has 25.5 pto hp.
   / 6' brush hog on a 30Hp tractor #8
My first mower was a 6.5 foot bush hog,, ( John Deere )
I owned a 404 IH ( gas ) tractor then,,
If the grass was over a foot tall,, I had to pull the bush hog to the top of the field,, and only mow going down hill,,,,,,,,
   / 6' brush hog on a 30Hp tractor #9
It depends. You may have owned a heavy five footer, and you may be replacing it with a new light weight six footer. Making the handeling of you new bush hog the same as before. Now if you have enough horse power all depends on what to are going over, and only you know that. May be an opportunity to investigate a newer bigger tractor. What do you think. Blessings come in disguise
   / 6' brush hog on a 30Hp tractor #10
NO 25 hp tractor will run either of my 6' rotary cutters in anything but light cutting, and even then, on a hot day you will be going like a turtle.
It will be hard on the tractor either way...
SR
24in excavator tooth bucket (A56435)
24in excavator...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
Air Compressor (New/Unused) (A59225)
Air Compressor...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
