Can this hydraulic cylinder be rewelded or do I need to replace?
   / Can this hydraulic cylinder be rewelded or do I need to replace? #11
That's one way to do it. Thanks for the update.
It's crazy that someone would charge over $100 or $150 dollars for a 10 minute welding job. Unbelievable.
   / Can this hydraulic cylinder be rewelded or do I need to replace? #12
ON-SITE being the key, here that would mean 1-2 hour round trip plus the 15 minutes to weld. Changes the numbers quite a bit.
   / Can this hydraulic cylinder be rewelded or do I need to replace? #13
Exactly. If you take it off, clean it up and bring it to a shop, it should not be close to $400. The onsite aspect is what is driving that price.
   / Can this hydraulic cylinder be rewelded or do I need to replace? #14
Still....
What would be the cost if the OP took the cylinder to a shop? $200? $300?
1985 American 48 ft. Dry Van Trailer (A50860)
1985 American 48...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
