Angle only going one way on my 6-way blade
   / Angle only going one way on my 6-way blade #1
Cephas71
Caterpillar D5K2 LGP 2012
Has anyone out there experienced this
   / Angle only going one way on my 6-way blade #2
Sounds like the pivot pin is a little tight. Does it have a bolt you can loosen, and can you get some grease in there to break it loose. Also the pivot pin could be bent.
No when I first crank it up the angle works. Once I'm running around a little bit it stops
   / Angle only going one way on my 6-way blade #5
IS it hooked into the remotes on the tractor? Try unplugging them and plugging them back in
   / Angle only going one way on my 6-way blade #6
It would help if we had some photos and more detail about when the issue happens. Under load? Is the blade hydraulic?
   / Angle only going one way on my 6-way blade #7
Based on his avatar, it is a 6-way dozer blade on his D5 Cat.:oops: If it is, it is different than what we typically think of when we talk about 6-way blades on this forum.
   / Angle only going one way on my 6-way blade #8
Could be a 6-way blade on a tonka toy for all we know at this point.
The quality of responses is directly proportional to the quantity of info given. And at this point.....it's near zero
   / Angle only going one way on my 6-way blade #9
If you look at the 3 responses that the OP has made, his issue with the transmission and blade are with his D5 Cat. I have no doubt that he has moved on to another forum. I doubt that there will be very many if any responses that help him from TBN.
The OP made 3 posts in 2 threads in 29 minutes last Saturday and has not been back that I can tell.
   / Angle only going one way on my 6-way blade #10
I suspect you are right.
I didnt see the other thread, and didnt even know he owned a D5 unless I clicked on his profile.
Thats the issue with TBN on a mobile phone (at least mine). Cannot see any profile or signature information unless you specifically click on the members profile.
Thats why its always a good idea to include details in the post itselflol
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
2015 CATERPILLAR 257D SKID STEER (A52709)
2015 CATERPILLAR...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
Mini-Excavator Heavy Duty Grapple Attachment (New/Unused) (A59225)
Mini-Excavator...
2009 Arco Trailer T/A 6,000 Gallon Tank Trailer (A56858)
2009 Arco Trailer...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
