Anyone ever drove over plywood on soft grass or mud w their tractor?
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #1
boostmg
Pennsylvania
Branson 3620 TLB Hydro
I’m doing a job, in a field where some areas can get soupy. After tons of research plywood seems like it might be the best route for me at this time.
I just wanted to see if anyone had done this before?
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #2
I've used aircraft landing mat very successfully. I think the pieces were 16"x96". It supported my compact tractor very well.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #5
You can get matts made for the purpose, some times even rentals.
They work much better.
Search for ground mats for equipment.
Have you seen how expensive plywood is?
Yep but cheaper than any other alternative I’ve seen
ill call and see if i can rent some maybe.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #7
A couple pairs of these might work.
You may find something similar for a better price, I just grabbed the first set I could find which wasn't on Amazon, Walmart, or Zoro.
3 pages into my search.
I remember when a search engine was useful.
   / Anyone ever drove over plywood on soft grass or mud w their tractor? #8
Three sheets work well for an excavator to leapfrog around on. Not sure how the smaller contact points of tractor tires would do and you would need enough to make a path. They can get stuck/suctioned down pretty tight after tracking over/working on them. Not sure you could pick them up and move them by hand without alot of effort.
My plan right now is to get 4 .. 4x8s. I would put them horizontal to the tractor. So i would stack four in front of me like an 8ft wide road. I reckon my tractor will fit on 3 then i would leap frog the free one.
Good point about them getting suctioned, i have a backhoe so i figure if I’m going forward i will get it loose with the backhoe. If I’m going backwards, get it with the bucket.
I imagine they weight a bit too and might weight even more if they get wet muddy. I may use my quad to help.
This is just how I’m figuring this all right now.
I think they just aren’t big enough.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
Black Stone 2X17 500 BTU/H Outdoor Gas Griddle (A50860)
Black Stone 2X17...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
