Midniteoyl
Super Member
- Joined
- May 20, 2013
- Messages
- 5,114
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Thanks, maybe I mispoke and they are not the pin nuts? They are the large nuts that keep all the loader joints together. I figure if they are too loose, would that not encourage side to side play when using the loader?
Thanks I would consider them snug now, they were quite loose in some cases. Not sure how the ear got bent, but it was not from me snugging the nuts. I put maybe 15lbft on them, if that.
What would contribute to having grease flow out of the face when I am greasing the pins? It is very obvious on some locations, and in others it is not an issue. You can see a little in this picture.
Yep, I understood which ones you were talking about
On my 4030 (no C) the pins are only held in by teardrop keeper and a C-clip:
Notice how loose it really is, so no worries about it not being tight.
As for the grease squeezing out, its normal. When you grease a pin, the old grease (and dirt) gets pushed out and is what you want. Just wipe up the old with a rag.
