Best way to cut pipe at an angle?
   / Best way to cut pipe at an angle? #1
bdog
Elite Member
Texas
John Deere 6130M
I have 2-7/8” oilfield pipe set vertically in the ground for a shed. It is already concreted in the ground. I need to cut the tops off at desired height with a 2/12 (9.5 degree) angle so I can weld the I beam for the rafter resting on top of the pipes.
I have one of those gadgets that slips over the pipe to mark a saddle, straight cut, or 45 degree cut but how do I go about making a 9.5 degree cut on the pipe?
   / Best way to cut pipe at an angle? #2
Here is a web site that has a large number of calculators and printable patterns that might help.
www.blocklayer.com
Go to "Printable Templates" then "Pipe Notching Templates"
   / Best way to cut pipe at an angle? #3
Maybe this will work.
On a scrap pipe, cut a 9.5 degree angle on a bandsaw. Then wrap it with light cardboard/stiff paper and trace the end. Cut off the part not wrapped around the pipe. Mark the high and low spots. Use this pattern to mark your standing pipes.
Bruce
   / Best way to cut pipe at an angle? #4
Pipe fitter's handbook has all the proper formulas to layout angles on pipe. And a good wraparound. There are some good videos on UT they could explain it a whole hell of a lot better than I could.🍻
   / Best way to cut pipe at an angle? #5
What tool (s) do you have to make the cut? Porta-band?
Build a jig that clamps / bolts to the pipe or to the porta-band to use as a guide
I have a 45⁰ & 22 1/2⁰ jig built so I don't have to mess with measuring / marking, etc...
Unfortunately they're in my storage unit 100+ miles away or I'd snap a pic & post it for you
   / Best way to cut pipe at an angle? #6
Porta-band and/or a Metabo. I'm making the assuption you already know how to calculate the angle and mark it.
   / Best way to cut pipe at an angle? #7
The angle cut from high side to low side is a little less than 1/2".
Not knowing the tools you have at your disposal or what the method of choice for welding is....I'd probably just eyeball it close with a sawzall....fine tune with a grinder to desired angle. Its welding, not finish carpentry. So the joint dont have to be perfect for a good weld to follow
   / Best way to cut pipe at an angle? #8
Just a piece of paper and mark out the angle using Tan tables. Then wrap it around the pipe for marking.
Thanks for the replies. I guess my issue is making the mark more than anything. I plan on making the cut with a torch. I can calculate vertically where the marks need to be. If say for example I was working with square tubing and not pipe I could make my marks and use a square to transfer them around to all sides of the square tubing. I am not sure how to do this with pipe.
As LD1 mentioned the difference is heights across the pipe is only roughly 1/2” but still if cut incorrectly that is a rather large gap to fill when welding in the overhead position. I also need to be able to balance a large heavy I beam on top of these cut posts so if the cut is wrong it is going to be very unstable while I am trying to weld it up there.
I am not sure what the “tan tables” you are referring to are Egon?
Monkey duster the block layer site is very cool and has a lot of information but the pipe notching templates I saw were all for pitting pipe to pipe. I need a simple angle cut to fit a pipe to a straight surface.
Bcp I like your idea and think something along those lines would work. This seems similar to what square1 suggested except manually marking it instead of building a jig.
   / Best way to cut pipe at an angle? #10
2-7/8 od pipe has a circumference of 9"
Draw a triangle on a piece of paper ....9" base with 1/2" height.
Cut it out, wrap it around the pipe. It will get you close enough for torch work.
Or find something round and easy to cut an angle on with a bandsaw or meiter saw. Ironically.....just finished some leftover pizza for lunch and the grated parmesan cheese container is round, plastic, and right at 3" diameter. Would make a PERFECT template. Cut on angle....slip down over pipe and mark.
197359 (A50458)
197359 (A50458)
2003 Chevrolet Silverado 2500HD Pickup Truck (A50860)
2003 Chevrolet...
UNUSED 2-Pack Yellow Ratchet Strap Set (A50860)
UNUSED 2-Pack...
Apache 8800E Gasoline Generator (A50860)
Apache 8800E...
Engine on Skid (A50860)
Engine on Skid...
Super Material Lift MH1000 (A51039)
Super Material...
