Mowing MMM idler pulley came off
   / MMM idler pulley came off #1
kfschaefer
Efland
MF GC 2400
I have a 60 inch mower which I thought was going to need a new idler pulley so I have on on hand. Today it came off just as we finished mowing. I cannot figure out how to keep the pulley on the mounting pole as I have the keeper pin but see no grove to put it in on the pole. I suppose I could get the bracket with the pulley mounted on it but would rather not since I have the pulley already. Has anyone ever just replaced the idler pulley successfully as I would love some tips that I am clearly missing.
   / MMM idler pulley came off #3
this part?
doesn't it use snap ring and not a pin?
are you maybe not getting the pulley down far enough to see the indentation?
mines all tarped up for winter now so cannot verify physically.
Thanks Dave as I meant snap ring. Here is a photo of a new and old pulley along with where the pulley goes without any grove.
The snap ring shown in your image is not the same in mine as it shows a snap ring underneath the pulley which makes no sense to me.
   / MMM idler pulley came off #5
sounds like groove area wore/broke off which would cause the pulley to come off.
thats a 2325/2326 mower right?
or is it the older mulching mower, think they made that 60 "
Good eye Dave as it is a 2009 model. I had not considered that the groove are may have worn out or broken. It does not appear to be broken so it much have worn smooth. Looks like I will need to get the whole setup to be sure. I thought I was so smart having a spare pulley on hand:) Thanks for responding as two heads are better than just one.
IF bearing fits stub ok, just drill stub at end and tap for threads and use bolt & washer to retain idler....
Good idea and will try that since it would be faster.
   / MMM idler pulley came off #9
Yep, just went out & looked at my 2360 and sure enough, there's a small snap-ring at the top of the idler pulley "axle." Drilling into that & tapping for a bolt & washer sounds like a great fix, if it holds up. You might want to use some thread locker on the bolt. Here's a pic -- (No extra charge for the dust, as they say....)
   / MMM idler pulley came off #10
what is model # of that?
the pic you posted showing that clip in that position been irritating the heck out of me LOL
2007 FREIGHTLINER COLUMBIA 120 (A58214)
2007 FREIGHTLINER...
2005 Ford F150 Pick Up (A55272)
2005 Ford F150...
1708 (A58375)
1708 (A58375)
1643 (A58375)
1643 (A58375)
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Deere 333G (A53317)
Deere 333G (A53317)
