cat2 to cat 1 top link for Branson tractor
   / cat2 to cat 1 top link for Branson tractor #1
southernboy
Member
After much research I replaced my JD 4720 with a Branson 5835r. Actually I kept the deere also. Anyway the Branson came with cat 2 3 point. Most of my equipment is cat 1. I don't mind using bushings on the side links but it is a pain on the top link. I have bought 2 different brand cat2/cat1 links and both cat 2 ends are to wide to fit the branson receiver . Does any one know of a source that would fit? I am considering a hydraulic link but it would be an online buy and I am worried it will have the same problem. I am not comfortable with possibly grinding the edges off the cat 2 bearing. Thanks for any ideas.
   / cat2 to cat 1 top link for Branson tractor #2
I am considering a hydraulic top link but it would be an online buy and I am worried it will have the same problem.
Contact MtnViewRanch, AKA Brian @ Fit Rite Hydaulics.
   / cat2 to cat 1 top link for Branson tractor #3
Do you have an angle grinder? You could just grind down the sides the cat 2 end on the top link. It will work just fine.
   / cat2 to cat 1 top link for Branson tractor #5
So you need 1 3/4" wide ball swivels at both ends? Is the tractor end a 3/4" or 1" pin? Not that it matters, I build them for what your application requires. (y)
   / cat2 to cat 1 top link for Branson tractor #6
Grinding off the edges to make it fit will not cause any problems.
tractor end is a 1 inch pin. I guess i might try grinding the edges off or else do the custom link. Thanks for replies.
   / cat2 to cat 1 top link for Branson tractor #8
Eight years ago I went from an OEM manual top link to a Fit Rite hydraulic top link. There are no problems and the fit is perfect.
I would guess the top receiver on my Kubota M6040 must be a tad wider. I've always had plenty of clearance.
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
2018 Ford Explorer SUV (A56859)
2018 Ford Explorer...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A57024)
Magnolia Trailer...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55852)
2004 Pierce Tilt...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
