Agri Fab Sleeve Hitch Rock Rake conversion
   / Agri Fab Sleeve Hitch Rock Rake conversion #1
fishman29
Wilsonville, AL
Kubota BX 2200
Hello all. Bought a Agri-Fab sleeve hitch rock rake, model 45-0366 thinking it had a 3 point hitch. It's brand new in the box but obviously no 3 point hitch, see pic. Anyone know of a 3 point hitch kit that I could attach to this? Thanks to all. Working on removing 60' - 70' oak lost in a tornado last year. Added a grapple to my BX2200 and it's working great but have many old trees constantly losing limbs. At 71, with back problems (like most) I'm tired of bending and picking up countless limbs.
I know I could probably get one fabricated but I would just as soon buy one.
Thanks.
fishman29
   / Agri Fab Sleeve Hitch Rock Rake conversion #2
If you can weld, you could possibly modify a trailer mover frame to fit with some added bracing from the main bar on the top and both sides to the trailer mover.
If you can weld and have time, build a 3 PH hitch using above mentioned bracing.
   / Agri Fab Sleeve Hitch Rock Rake conversion #3
I'd buy a cross drawbar for 30-40 at my local TSC or similar and probably a U-bolt with a chain for the top link if I wanted it working in 20 minutes. Looks like you already have a place to bolt the bar to or drop a pin in it.
   / Agri Fab Sleeve Hitch Rock Rake conversion #4
If it is a 2 inch square tube, cut off the sleeve hitch, drill for pin and use it on a 3 point receiver hitch like mine:
   / Agri Fab Sleeve Hitch Rock Rake conversion #5
How would a rake on a sleeve hitch even work? It seems that it would just catch something and turn sideways or angle.
   / Agri Fab Sleeve Hitch Rock Rake conversion #6
Sleeve hitches don't pivot.
Thanks.
fishman29
If you don't have a 3 point receiver hitch this would work: Ballard Fabrication
   / Agri Fab Sleeve Hitch Rock Rake conversion #7
It sure looks like the one in the OP manual does.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
NEW HOLLAND TS115A TRACTOR (A58375)
NEW HOLLAND TS115A...
