Ideas to protect the hydraulic filter?
   / Ideas to protect the hydraulic filter? #31
We run Zooks Welding filter guards on the L and MX units, top notch design and very heavy duty
Here's a pic of the Zooks guards:
rs=w:352,h:480
The problem I have is that my L4330 has those torque bars (?) that go from the torque tubes to the rear axle, see pic below:
iu
   / Ideas to protect the hydraulic filter? #32
rs=w:352,h:480
iu
I think I would look at cutting a piece of steel plate and u-bolt it to the bottom of your bars. Without being able to look at the tractor you could notch out the plate and cover a good bit of things that could be damaged. A skid plate that could be dropped down easily
   / Ideas to protect the hydraulic filter? #33
Good idea on the U-Bolt! One thing that has been holding me up on fixing mine is that I really really don't want to drill through that 1/2" steel bar. The biggest fear is weakening it for FEL operation; the 2nd is that drilling sideways is a huge PITA.
   / Ideas to protect the hydraulic filter? #34
M59 loader control valve and lines in similar place. Factory has a sheetmetal cover that helps some but had damage with the type of work I do.
Combined building a bolt-on chainsaw and tool holder with skid plate and armor to protect the hydraulics. The filters are located differently and could use some armor too.
Tractors aren’t forestry machines but shouldn’t be so easy to damage from going into the woods or handling brush.
   / Ideas to protect the hydraulic filter? #35
I decided to upgrade tractors and bought a MX5400 which has more protection for the axles, hydraulic lines and filters. I didn't buy it for just that but for the ability to go out in the woods without too much worry of damaging parts of the tractor.
This is The Way.
Why spend $200-$300 when you can spend $30K-$40K to solve the problem!
Way Mo Bettah!!!!!!
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57192)
KNOW BEFORE YOU...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2015 MACK ELITE...
UNUSED WOLVERINE SG-13-08D HYD 8" STUMP GRINDER (A57193)
UNUSED WOLVERINE...
2009 Toyota Highlander SUV (A55853)
2009 Toyota...
COMAC 72' HYD ROCK GRAPPLE BUCKET (A57192)
COMAC 72' HYD ROCK...
