Kubota Operator Protection Circuit OBC bypass
   / Kubota Operator Protection Circuit OBC bypass #1
SamWalton
Sallisaw Oklahoma
Kubota B26 TBL
For those of you who have had the pleasure of finding and repairing the OBC circuit to have the privilege of starting and operating your tractor Here is a simple way to at least have a bypass switch in place to avoid the inconvenience of the breakdown. Simply install a jumper between the Black White and Black Yellow wires in the connector body of the OBC controller connector.
   / Kubota Operator Protection Circuit OBC bypass #2
Cool!
I wonder if this would work on other models?
I've often wondered what I'd do when it happens to me.
   / Kubota Operator Protection Circuit OBC bypass #3
Cool!
It should work on your B3030 if you should find yourself in that situation. It simply bypasses the controller and sends voltage directly to the starter when you turn the key to the 'Start' position.
These two wires are connect the starter solenoid to the start position of the key switch through the OBC relay. A screwdriver jumped across the power terminal at the starter to the solenoid will turn over your tractor.
   / Kubota Operator Protection Circuit OBC bypass #5
Thanks for the explanation-we are bypassing the OPC and sending the start trigger current to the starter solenoid.
I would assume that the OPC will still shutdown the engine if a safety switch is activated?
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
golf cart electric (A55787)
golf cart electric...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
