Buying Advice Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac)
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #61
Found a nice 2016 with high flow, traction control and power bobtach in Wisconsin at a Bobcat dealer. 39K or $41,500 with a Bobcat bed mount material spreader
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #62
If I had to do it all over again. I would probably go for some small European articulated tractor with a hitch and pto on both ends. HOLDER for one, although NONE of these is well supported over here. And then still get a small wheel loader for loading and that kind of stuff.
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #63
Are there any tractors that have the cylinder standard on the quick-attach. And are there any tractors that can run high-flow attachment (33 gpm with high-flow lines)?
Power SSQA is an option on the Kubota Grand Ls. I think it was almost a $2k option if I remember choking & skipping it when I bought my L4060. The cylinder alone runs $800+ at Messicks last I looked. Way cheaper to DIY it with a standard cylinder & making your own brackets.
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #64
I like the 5610 with the 3 point.
This is an eight foot wide box blade on the 3 point leveling some hauled in dirt:
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #65
And more info for future info seekers on the push/pull capabilities of a Toolcat
On the front a six foot wide box blade on a three point adapter that is on a Tilt-Tach:
Bulldozer mode pushing dirt:
And on the three point adapter, no Tilt-Tach, pulling and leveling dirt:
@Xfaxman Adding another update to this thread. A few months after starting this thread in 2019, I bought a ~1997 Deere 755, mostly for mowing. I sold that at the end of the summer and then bought a Kubota L4330 GST. Much of my 14 acres is very uneven and I feel really tippy in all but the few acres around the house. Just before buying the Kubota I rented a Bobcat T650, which was a beast around the property and very stable. I also rented the rotary mower and tiller, which chewed through 3-foot grass and turned two acres without any issues.
After the Kubota sels, I've decided on a ToolCat. Maybe a 5600, but I will likely hold out for a 5610 F-series. For my needs, I think the ToolCat will work just fine.
Question: How much better is the G-series over the F-series? Are there any G-series years to stay away from? Any major improvements in a specific year of the G?
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #67
@Xfaxman Adding another update to this thread. --------------------------------------------
The reason I traded our F Series in on a G Series in 2017 was to get Traction Control.
I am not aware of any changes, but have not been looking at the newer ones.
A good feature of the Toolcats is no Regen that I read so many complaints about.
@Xfaxman How does the G-series handle Tier 4 without regen?
Have you noticed any quality/reliability differences between the F and G series?
Do you notice the additional 5 horsepower of the G?
   / Is there anything comparable to a Bobcat ToolCat (besides Power-Trac/Ventrac) #69
The new Bobcat engine, Here is info from their Website:
When Tier 4 emissions standards required every equipment manufacturer to make equipment changes, Bobcat designed a non-DPF Tier 4 solution that also delivers new features and provides more performance to customers. It reduces downtime that occurs with DPF regeneration and long-term DPF maintenance costs.
No.
No, never had a lack of power on either one for what I was doing.
Just came in from working on relocating part of our driveway:
Moved the box blade to the front so I could see what it is doing:
@Xfaxman How would you compare your V417 to your 5610?
2013 Fiat 500 Sport (A56859)
2013 Fiat 500...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
60" ORANGE PIN ON BUCKET (A57192)
60" ORANGE PIN ON...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55852)
Mohawk 12,000lb...
2011 John Deere 3038E (A53317)
2011 John Deere...
